Question about Coffee Makers & Espresso Machines
Machine keeps asking to fill the beans. It is full?
crouchdash
  • 83 Answers
SOURCE: keeps saying refill beans when it is full of beans
the float switch is stuck. need to clean it out.
Posted on May 11, 2009
  • 60 Answers
SOURCE: Jura F70 Coffee Machine isn't responding to the
The Touchdisplay is defective. You need to send the machine to service to have the display changed.
Posted on Oct 06, 2009
  • 1089 Answers
SOURCE: The machine says FILL BEANS but beans are in
Hi
Oily beans (shiny) can some times stick together after grinding with a fine setting. Try opening the grinder setting to the very coarsest setting and see if it will clear the passage. If you have pushed the brew button an lot of times you may have packed the grounds in the passage which will have to cleaned manually.
Once you have the grinder working again, open it to the coarsest setting to clean the burrs. 1 time is enough. To turn the grind setting back down to your setting make sure that the grinder is running at that time. You can open to a coarse setting any time but it has to be running to finer.
Posted on Nov 12, 2009
  • 29 Answers
SOURCE: Display reads fill beans, but bean are filled. I
This sounds like the grinder is not strong enough to grind properly. Try adjust the grind to a bit coarser, if this makes no difference then the bearings inside the grinder may gone. Try only fill a small amount of beans in the container and see if it works. It may be that when there is too much of a load on it it will not spin the blades.
Posted on Mar 29, 2011
  • 6 Answers
SOURCE: Jura j5 keeps indicating beans
Sometimes certain beans do not move freely throughout the grinder. Oily beans, which is not necessarily a bad thing, do not fall into the grinder easily and tend to stick. It is necessary to sometimes to just poke or stir the beans around with your finger to make sure they fall into the grinder. For a safety measure do this while your machine is turned off.
Posted on Apr 20, 2011
Delonghi problems
More than likely the grinder is either not grinding at all or there is a blockage preventing the grounds reaching the brew chamber.
Jul 18, 2014 | DeLonghi Esclusivo Gran Dama EASM6600...
Fill beans
the coffee beans are not entering in the grinder disks and since they rotate without coffee the machine understands that their is no beans. You need to clean the grinder disk and grinding coffee funel to bee sure their nothing blocking the coffee movements. Use a vaccum cleaner and try to clean everything in grinder and grinder exits. Try also the machine by regulating thegriding to more gross coffee and when it will start grinding normal then you can udjust step by step back to grinding position you have at the begeining.
Feb 27, 2012 | DeLonghi ESAM 5500M
Problem I had is kept asking me to fill the bean container when is already full? keep finding unused grounds that have fallen behind the grounds tray.
Try to power cycle the unit to clear the bean warning, unplug it and let it set ten minuts to clear the memory. As far as the grounds, make sure your not overfilling the unit and all the bean cup and grounds trays are inserted correctly. you might have to tip it and clean any trapped grounds out of the tray area to make sure the tray seats correctly.
Dec 30, 2011 | Krups Super Automatic XP 9000 Espresso...
Keeps saying fill beans container when already full
The machine understant that there is not any beans in the container by the mesuring how easily the grinder motor rotates. If there is not any beans in the grinder motor rotates freely. In your case means that the beans from container are blocked to enter down to the grinders disk plates or they partialt enter, so the motor runs more freely and machine understant that there ae not enough beens. So you need to remove the beans and container and by the use of a vaccum cleaner remove all remainings from the grinders entrance and funel. You can also use a brush to remove any coffe oils and remianing so the bean can easily slide inside the grinder.
Jun 25, 2011 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Jura j5 keeps indicating beans need filling once a button for coffee has been depressed. then indicates ready again. Beans are full and I have tried blocking off the sensor (beans full) but still the...
Apr 20, 2011 | Jura Capresso Jura / Capresso IMPRESSA J5...
Hello! on the screen it appears "Fill beans
hi you need the grinder stripped and serviced .. or might need new grinder... bsc appliances 07779933829 we have a postal service to repair too.
Feb 27, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
The readout keeps saying "Fill
u need the grinder stripped ..might need spares ? bsc appliances 07779933829 we carry out repair service via post anywere..
Dec 14, 2010 | DeLonghi EAM3400 Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
