Question about Water Water Heaters
Edwards Solar HWS Comfort 200 Gas Booster is not heating water hot enough
gary1121
  • 332 Answers
SOURCE: Low Water Pressure Gas System but High Pressure when Solar Water
if you have a gate valve on the unit from the hot water tank it could be as simple as the valve on the gas system being clogged going to that bathroom,, from how it is described it sounds like that would be the problem check to make sure all valve are not stuck in the on position ans change the valve if it is frozen in place
Posted on Jun 06, 2009
mrhotandcold
  • 248 Answers
SOURCE: newly installed solar edwards hot water system and
system over/pressurised check overheat statbest of luck
Posted on Oct 31, 2009
  • 1015 Answers
SOURCE: water heater heats water, but not long enough or
The first thing I would do is turn up temp control on gas valve.Control is located on front of gas valve at the bottom front of heater.They usually have a indicator dial on front with an arrow pointing direction.Turn dial to higher setting when burner is not on and this should turn burner on and provide hotter water. The control is normally turned clockwise to increase temperature.If control is already turned all the way up then water heater may need to be replaced.Depending on water quality in your area heater may have a large amount of mineral build up and it may not be capable of producing enough or hot enough water. If this the case all I can suggest is to try to drain tank and flush some of the deposits out. If you have installation manual it will give you instructions on how to do this. If not see if you have working shut off valve on cold water line ,if it works shut it off and connect drain hose to drain valve on bottom right side of gas valve. Put hose to floor drain or sump basin if you have one. Turn control knob on top of gas valve from on to pilot,this will leave pilot light on but prevent burner from working while draining. Open drain valve ,flow rate may be slow or not at all. Open hot water side of some faucet to provide air to help draining. You may try opening water supply valve to heater a few times to aid in draining. If you can get it to drain,shut drain valve off when done,turn cold water supply back on and shut off hot water outlet. Then when tank is full open hot water vavle to bleed air out of heater and piping. Turn control knob on top of gas valve back to on position. This should bring burner back on .It will take about 1/2 hour to heat. If you can't get it to drain or this doesn't help you might consider getting a new 40 gallon heater. Hope this helps. Thanks
Posted on Nov 11, 2010
  • 5245 Answers
SOURCE: not enough hot water ge smartwater water heater gas
1) Copy following links:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Low temperature setting, extremely cold incoming water, Water leak or broken pipe running hot out of tank, crossover caused by bad faucet cartridge or bad recircirculation check valve,, bad gas control valve thermostat.
Posted on Feb 20, 2013
SOURCE: drayton dc1100 controller problem, adjusted heating times but now hot water is cold??
You may contact authorized Service Center.
Posted on Apr 23, 2014
Solar hot water not hot
Solar hot water giving you cold showers? Eight tips to warm you up.
Eight tips to get the most from solar hot water
We argue that policy needs to look beyond installation and that installation practices need improving, but what can you do to get an effective installation?
First, seek out independent advice from sources such as local sustainability events and organisations. They can help you understand what suits your circumstances and what characterises an effective installation.
A good organisation is theAlternative Technology Association. They provide free advice to members, sell a solar hot water guide, and organise open house events where you can see and discuss domestic sustainability technologies.
Second, consider whether solar hot water is the best option. It may be that a hot water heat pump or an instant gas system is a suitable choice, depending on where you live, how much cloud cover you have, or what sort of building you are in.
Third, make sure all your hot water pipes are insulated, especially the pipes that go to and from the tank and solar panels. You typically need insulation to be 15 mm thick. Without proper insulation you could lose half the energy you are trying to collect.
Fourth, get a booster switch installed in a convenient place inside, so you can easily turn the booster off if there is plenty of sun, or on if it's cloudy or you need more hot water.
Fifth, if you go solar, install a system that has a sufficiently large tank matched with a sufficiently large solar array for your needs. Water is very good at storing heat. A large tank could help you store solar energy for those rainy days.
Sixth, you may need to change electricity tariffs if your booster is electric, to ensure the sun gets a chance to heat the water before the electricity does.
Seventh, you may need to change your peak hot water use habits so that the tank water is at its coldest after morning use, after which the sun can then heat it during the day. The booster can "top up" overnight, ready for morning showers.
Eighth, before you install solar hot water, examine and discuss household expectations around hot water use. Will they need to change? Are members of your household prepared to make that change?
This may be the most profound change you can make, but also perhaps the most challenging.
Oct 30, 2016 | Water Water Heaters
Cold water side will not get cold
we are loss to understand this question
with hot water systems the water in is at normal temperature ( day /night ) and it is heated either by solar to electric/ gas to make the water hot
the hot water system will not make water colder only hotter.
Apr 09, 2015 | Water Water Heaters
My rheem solar hot water isn't heating the water.
you need to verify flow from the panels to the heater booster. I suggest you contact your home inspector (if you had one done) or the prior owner, the inspector should have seen this and the prior owner is usually happy to help.
Sep 17, 2014 | Water Heaters
Edwards hot water system
just a reaction with the copper fittings
Apr 03, 2014 | Water Heaters
No hot water
10-22-12
Copy following links to help identify product and download possible troubleshoot resources:
Tank-type gas
Tank-type electric:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Rheem tankless:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Other types of water heaters include boiler, tankless electric, indirect, solar-assisted, solar, hybrid electric, heat pump, wood-burning, gas hybrid, 3-phase commercial electric.
Oct 21, 2012 | Rheem Water Heaters
How to design and calculate the solar heat panel for hot water system for the concentrated 100 nos. staff toilets and changing rooms of commercial building in Beijing. What is the basic and ancillary...
Usually toilets do not require hot water.
Is the plumbing divided into hot and cold water pipes?
If toilets are hooked to hot water, how many flushes and how many gallons per flush per day.
What is the expected consumption per each worker?
What is the latitude from equator, and expected solar input. Further north, and hazy atmosphere reduce input. Beijing has smog I believe.
How often is the solar panel going to cleaned of smog and dirt for maximum collection?
If the area has hard water, then the entire system is prone to sediment build-up and failure unless water is artificially softened.
Solar water heater temperatures can exceed 180 degrees at times. This temperature will damage storage tank that is not made for that temperature.
Most solar water heater systems have pressure regulating valve and expansion tank to accommodate occasional high temperature and pressure.
A good fellow to contact might be at following website:
http://www.builditsolar.com/Projects/WaterHeating/water_heating.htm
Solar collectors are usually connected to a circulating pump, and then the heated water is stored in a tank.
The pump circulates water continually from solar collectors through a storage tank.
This type of system would use ordinary tank-type water heater for storage.
Most of these systems also utilize a back-up heating element inside the tank.
More complicated systems circulate special liquid through spiral tubes inside the water heater.
This type of heater would be an indirect water heater.
Indirect heaters are used for solar collectors, and used with boilers, or any outside heat source.
http://www.bockwaterheaters.com/Products/products_coil_tank_water_heaters.html
http://www.hotwater.com/products/residential/cirrex_solar.html
http://waterheatertimer.org/images/solar-water-heaters-on-roof_lbiRv_5784111-500x282.jpg
Oct 05, 2011 | Water Heaters
Bosch tankless hot water heater: Confort TOO HOT!!!
Look for a water temp control on unit. Otherwise a lower temp can be attained by having a higher water flow to minimize temperature buildup in heating coil.
Sep 06, 2017 | Bosch & Tankless LP Hot Water Heater
May 22, 2009 | Water Heaters
Water Heaters Logo
167 people viewed this question
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
