SOURCE: restoring deleted files
You could try an in place reinstall.. this will "Replace" ya windows & leave (hopefully) ya system intact.. From below the first one, the winnt32.exe method I have used B4 and it works very well. http://www.jsifaq.com/SF/Tips/Tip.aspx?id=8127 http://support.microsoft.com/kb/315341
SOURCE: msn.exe error
Well reinstalling the program will help, and should not overwrite you setting or personal data.
SOURCE: what is a 211 error code on a tajima 2 head emb
A 211 is generally caused by the degree wheel not resting in the "red" zone. This zone indicates the machine is in a ready state to start or shift. Look at the degree wheel and manually move it to the zone (around 100-110 degrees). If this doesn't work it will need repaired. It usually takes 1-3 hours depending on what is involved.
