Question about Refrigerators
My KIC fridge I can hear the sound that is working but is not cooling
4 Suggested Answers
  • 99 Answers
SOURCE: compressor working but Fridge and Freezer not cooling - Amana
It sounds like the same problem my brother is having with his. I took it apart and found that the fan that moves all the air for cooling is not working. This fan is behind the bottom panel in the freezer side, and sorry you do have to take everything out to get to it.
Posted on Jul 30, 2010
  • 1099 Answers
SOURCE: My double door KIC fridge(Freezer
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrigerator 's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Using a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrig control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the advisable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Good luck and take care....
Posted on Aug 13, 2010
  • 43501 Answers
SOURCE: Good day, I use a KIC
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
Posted on Apr 17, 2011
I have KIC frigde it is hot intead of cooling
Could be a number of things.... no freon ( somebody tried defrosting the freezer with a knife & punctured the coil, the fridge might need defrosting..... do you have power to the fridge?
May 07, 2017 | Refrigerators
I got a KIC fridge The freezer on the bottom is working well. The top is not cool its hot in side.wat can be da problem
Evaporator (cooling coil) fan motor is not operating or a component failure in the defrost system which comprises the defrost timer, defrost heater, or the defrost safety termination thermostat.
Jan 26, 2015 | Refrigerators
My kic fridge have 2 compartments. Freezer and fridge. only the fridge part dont work help please
The freezer is where the heat is removed from the box and cold air should circulate from the freezer into the refrigerator section. Something must be blocking the vent between the two. There is only one cooling unit; it cools the freezer and is also vented into the fridge for sub-freezing temperatures.
Nov 26, 2013 | Red Line Mens Classic Gmt Black Dial Black...
I have a KIC 2 door fridge freezer. The freezer works but not the fridge part. It was working till a few days ago. The evaporator was frozen so i switched it off to defrost it. Since then it doesnt co
Check that your evaporator fan is operating. If it is, then take the rear freezer shield off and blow warm air down the cooling tubes to defrost the tubes. One of more of your cooling tubes is frosted up.
Jan 23, 2012 | Refrigerators
Hi I have a very old KIC fridge freezer the freezer is cold and works well the fridge is not icing up on the back board in the fridge everything going off in the fridge what could be causing this?
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
This will help.Thanks.Helpmech/.
Nov 01, 2011 | Refrigerators
KIC fridge not getting cold freezer ok , regassed 30 days ago
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
Aug 27, 2011 | Refrigerators
My kic fridge is not freezing whereas my freezer is overfreezing. Can you tell me what is wrong with it.How can I get it fixed.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Sep 06, 2010 | Refrigerators
My KIC KTF255P-Aa Fridge is heating up
It's in defrost cycle, But it's getting to hot. has a limit on it think it's not working.
Sep 22, 2009 | Refrigerators
KIC 223l fridge - what length time reqd to let gas settle?
if it was transported upright you should be able to plug it up right away and allow it to start cooling peyton..
Jan 28, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
