Question about The Computers & Internet
Trying to export audio tracks to usb from Korg D3200. Everytime i hit execute, it says the file name is already in use even though ive renamed it many times
SOURCE: usb file transfer
The initial software for the 2488 had a bug that would not transfer tracks that had punched in audio correctly. The file would transfer with missing audio. This was corrected in a software update. The work around was to rerecord any tracks with punched in audio to a new track then export.
Once this is corrected on a machine normal transfers and exports can be used. WAV files can be exported but have to be copied to the FAT partition on the 2488 then USB to a computer for inport to a DAW.
The FAT partition comes up as a USB drive. Realize that there are several ways to backup and or export your songs,files or tracks depending on your need. IE edit in Protools, move songs to another machine etc.
hope this helps
BB
Posted on Jan 23, 2008
SOURCE: Audio Driver file SP38615.exe downloaded from HP Compaq site after installation not working
HI
Try loading this drivers ftp://ftp.hp.com/pub/softpaq/sp37501-38000/sp37981.exe
Thanks
Posted on Jul 13, 2008
  • 10 Answers
SOURCE: Electronic drum kit, with USB out, problem
Sounds to me like you have the midi tracks outputting to the microsoft midi mapper or wavetable synth, which is built into the sound chip in your pc, and that this is conflicting with the mobilepre sound card - midi is just data, no audio, needs to drive some kind of synth. what you want to do is disable your internal sound card thru device manager, then just use the m-audio mobile pre as the input/output sound card in ASIO mode - you'll need to monitor via the headphone jack on the mobile pre or plug speakers into the line outs on the interface.
Then do tutorial 8 (in help files) on using soft synths - INSERT>SOFTSYNTHs creates a midi track and an audio track in a track folder.
Good luck.
The dude.
Posted on Aug 07, 2008
  • 189 Answers
SOURCE: Rename a song file after copying
I'm a little unclear about what you are trying to do. I'll assume that you have copied a song from one partition to another and now wish to change the song name so as to avoid confusion. To do so you need to call up the 'menu' (press menu button) and under 'song' go to 'load'. There you'll see a list of song names (including the song you have currently loaded and are working on). Just navigate to the song name and press the 'title' button (shift - menu) which will allow you to edit the song name. You don't have to reload the song for the title change to keep and you'll see the new title reflected in the LCD window after you press 'home' to return to the normal view.
Regards,
bd.
Posted on Dec 15, 2008
  • 117 Answers
SOURCE: Flip will only export audio althought it is in a AVI file.
Flip Video Converter is a gorgeous application for Flip video camcorder (the Flip Ultra, the Flip Ultra HD, the Flip Video Mino, and the Flip Video Mino HD) users to import Flip video files into Window Movie Maker for editing, like crop out black sides, trim video clips, merge multiple flip videos into one file, and add special effects.
spacer.gif icobuy.gif Buy Now spacer.gif icon-downarrow.gif Free Download Flip Video to Windows Movie Maker spacer.gif How to use Flip Video Converter
How to import Flip video files into Windows Movie Maker (avi, mpeg-1, wmv)?
Step 1: Connect Flip video to Computer
Slide USB latch down. USB arm flips up automatically and then plug it into USB port on computer. Save your flip video files to your computer with FlipShare, a built-in software that makes organizing, editing, and sharing video incredibly simple.
Step 2: Launch Flip Video Converter
Open the captured Flip video files from your hard disk, and add them into Flip Video Converter, you can load one or more flip video files or the whole video folder at one time. The loaded files would be shown in the info list.
Step 3: Edit video-Trim, Crop, Effect
Trim: By setting the start time and end time for flip video, you can get your most wanted video clips.
Crop: Drag and drop the dashed-lines around the video, you can cut out the unwanted black sides.
Effects: You can get personalized videos by adding vivid effects, like Gray, Emboss, and Old film.
Step 4: Output Settings
Profile: Select your target video type from the drop-down list. AVI, MPEG-1, WMV is fit for Windows Movie Maker.
Output: Specify the output folder the ready-to convert files.
Settings: Click it, you can set exact video audio parameters in the pop-up window.
Merge into one file: Tick it, you can join several flip video files into one file.
Posted on Sep 11, 2009
How to recover deleted data
you can obtain undelet software to do this but do not use the machine too much before attempting the procedure, too much use might lead to the areas where data was stored becoming written over. If the data was very important I would contact a data recovery specialist, one with a proven track record.
Good Luck
May 27, 2015 | Korg D3200 Digital Studio
Bounced trks 3&4 to 7&8 clicked on wav file button canceled says out of capacity
You have a memory problem. If you are using a flash card for memory or a CD drive or perhaps you have configured an external drive, you need to free up some space. Try deleting tracks or songs you don't need anymore.
Each song is independent on a CompactFlash
without affecting other songs. You can give a desired song name for managing recorded songs
(see pages 23 and 91).
Recorded track data is stored in a song as mono WAV files.
The MR-8mkII can convert the two WAV files recorded on tracks 7 and 8 (L and R) to a stereo
WAV file (see page 115).
You can export the converted stereo WAV file to your USB-connected personal computer, and
use the file by a music software application or make an original audio CD on the computer using
a CD burn software application. You can also burn an audio CD by using an external CD-R/RW
drive connected via the [USB HOST] port of the MR-8mkII (see page 115 and 123)
Fostex MR 8MKII Owner Manual Page 73 Fostex MR 8MKII Owner Manual Exporting Data To Personal Computer...
Are you using the auto delete feature? Get rid of data you don't need here: http://www.manualslib.com/manual/53326/Fostex-Mr-8mkii.html?page=135#manual
May 25, 2015 | Fostex Mr8 Mkii Mxl 990991 Recording...
IMPORTING FILES INTO THE KORG D3200
The import needs to happen from a computer (or a CD-RW) >D3200, not from a flash drive or backup drive.
Feb 12, 2014 | Korg D3200 Studio Package
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
From iTunes, I have converted the m4a track to WAV and then copied that over to my Tascam DP-02CF via the USB connection. When I go to import the track it says "Import file not found". What am I doing...
Your wave file is probably in stereo and you need to change it to mono. I use the free Audacity program to do this.
Once you have uploaded your wave file into audacity on the left side click on the down arrow which will bring up several options, click on the 'split stereo track' option. Then delete one of the tracks. You can then export the file as a wav file, you might want to rename with mono in your name so you don't write it over your previous stereo file. You can then import the file into your DP-02
Feb 14, 2010 | Tascam Dp-02cf Digital 8-track Recorder
EZ Audio Converter does not export files to iTunes
I've had exactly the same problem, and so far no resolution from Ion. A small bit of good news: the .wav files are on the hard drive, although without any track info. At least on Vista, they are in username/AppData/Local/Temp. The files are name Temp0, Temp1, Temp 2, ...
You can use iTunes to add these files (File/add file) and then convert them to .mp3s, or whatever format you prefer. Or you could convert them first using the tool of your choice, such as Audiograbber.
This is inconvenient, but a lot better than re-ripping the vinyl after EZVinyl hangs.
Jul 25, 2009 | Numark PT01 Turntable
USB Playback order is wrong
Ive just had the same problem with my Kenwood KDC-W6041U
What has worked for me was to rename the tracks at the beginning of the file name i.e.
01-track
02-track
Not
track-01
track-02
Jul 09, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Tascam DP-01 master track too big to export
Here is what I did to solve this issue:
1. Open up the USB connection on your DP-01 so that you may plug into a computer:
MENU-
Mar 24, 2009 | Tascam DP01 All-In-One Recording Package...
Tascam DP-02CF: How to transfer files to my computer?
You can't see the fat partition from within the DP-02. It's there, but only your PC will be able to read the contents of the fat partition when you have the USB 'opened' on the DP-02. The manual states that if your CF card is less than 5 Gb in size than you will only see/be able to select one partition. The default CF card that comes with the DP-02CF is only 1 Gb.
If you've created a backup or exported your wav files properly and everything is working ok with the CF, then you should be able to see backup or wav files showing up in the fat partition while connected to the PC. Even if nothing is backed up or exported you should still see the directory structure from your PC with the three folders, BACKUP, WAVE and UTILITY. As you are not even seeing these directories, what may have happened is that the fat partition had become corrupted or these folders had gotten erased.
I would have thought that reformatting the FAT partition would have fixed this problem however and that the DP02-CF would automatically recreate the required directories on the CF media after a reformat. The manual is unclear on this however.
So a couple of things you could try:
1. You describe opening the USB connection as 'push the USB button and then hit enter'. I was assuming you meant that you were selecting 'usb' from the menu and then pressing the 'enter' button to open the usb connection. You may wish to verify that the usb connection is being opened properly first.
2. If the connection is opening ok, and after a reformat you still aren't seeing any folders in the fat partition while connected to your PC with the usb open, you might wish to try to recreating those directories in the FAT partition yourself. While accessing the FAT partition (DP-02CF's removable drive) from the PC create the three directories exactly as named in the manual (WAVE, BACKUP, UTILITY). If that works, disconnect from the PC, try exporting a track or backing up a song again, and reconnect to the PC to see if you can see/access those files now.
Best of luck.
bd.
Jan 02, 2009 | Tascam 2488 Portastudio Multitrack...
Usb file transfer
In reading and working with the unit, I have learned that the file transfer is for backup only. If you want to manipulate the file they have to be transferred individually via your sound card or an interface.
Jun 21, 2007 | Tascam 2488 Portastudio Multitrack...
Computers & Internet Logo
42 people viewed this question
Top The Computers & Internet Experts
Carl Rick
colinat108
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
