Question about Laser Measuring Tools & Sensors
PLS2 palm laser not self leveling - Laser Measuring Tools & Sensors
3 Suggested Answers
SOURCE: PLS2 laser level, horizontal line very dim, vertical line ok.
PLS 2 Palm laser; dim horizontal line. vertical line OK
Posted on Nov 12, 2010
  • 87 Answers
Laser diodes are no like light bulbs. When a light bulb burns out, it goes black. When a laser diode burns out, it goes to an extreme low power state. You can see red at the source, but there is no beam to speak of. If this is what you're seeing, then contact Dewalt. They are low quality instruments, but will try there best to get you a new one, at a reasonable price.
Posted on Sep 05, 2015
Can I repair my pls2 laser level
Would it need a new battery? If so replace at
Jul 11, 2016 | Laser Measuring Tools & Sensors
How do I check if my dewalt spinning laser is accurate?
Set it up and shoot 4 level points around the laser . Like at 12 -3-6and 9 o clock. Move the laser 15 or 20 ft from where it is now and re-shoot those 4 points again .if they don't read level then your laser needs calibrated
Jan 07, 2015 | Dewalt Self-Leveling Line Laser...
Lazermark won't self level
There are 2 leveling systems in the lasermark lasers. The original was belt driven. The belts are rubber O rings, and break down over time. take the bottom off the laser and you can replace broken belts. It's a simply yet elegant system.
The newer ones use leveling cams. A tear drop shaped wheel on a motor, that raises and lowers one end of an axis to tilt the laser. The problem is because they have a hook at one end, they put a magnet in the cam to tell the laser when to stop turning the cam. If however, it reaches the limit, and then gets bumped it'll get the leveling axis stuck in the hook of the cam, and because the magnet is there, it will never relevel. What you have to do is, disassemble the laser, unplug the leveling motors and pull the wires for the magnet sensor out of the stuck axis. then swap the sensor from the other sensor in (as it wont level without reading the sensor) and then turn the unit on. It should be able to level at that point. The put all the wires back where they go, and you're on your way.
Apr 20, 2014 | CST/Lasermark Self-Leveling Rotary Laser...
The off level light doesn't turn off therefore doesn't level at all,
Your vial and compensator no longer match up. Move the foot screws until you can get your laser to spin, then adjust your leveling vial until it reads level again, using the 3 screws holding the vial inplace.
Aug 18, 2013 | Spectra Precision Laser LL500 Exterior...
Laser is level but out of level light blinks and will not spin
Your compensator and leveling vial are no longer aligned. Use your foot screws to find a place where the laser spins, then use the 3 hex head screws on the vial, to adjust it to read level.
Dec 23, 2012 | Spectra Precision Laser LL500 Exterior...
We have a bunch of PLS180 units that are out of calibration. Is there any way to adjust these back to level. I have some concerns about opening up the unit after seeing the warning about laser radiation...
The manual describes the procedure for checking level and plumb for the PLS180 but if you have determined that your units are out of calibration you are right to be concerned about opening the unit yourself. Please contact PLS at 1-800-601-4500 to find an authorized service center for your lasers.
If you cannot locate your manuals to check level and/or plumb I an attaching a link to the PLS180 manual as the methods for confirming level and plumb are quite detailed and should be followed exactly as described.
Have a great day.
Dec 30, 2010 | Pacific International Pacific Laser...
Laser is not rorating after tripod with laser tipped while it was in use )roatting ). Any help?
check to see if head spins by hand head gears may be jammed is it fully leveling it will not spin unless completely leveled could be loose connection from fall A.P. Service & Supplies 610-944-8030 repairs lasers free estimate
May 26, 2010 | Spectra Precision Laser HV401 4 Automatic...
How do i calibrate a PLS 180 laser
the pls is a pendelum system you need to open it from the rear and shift the weight it is usually a set screw that you turn in or out to change the resting pointof the pendulem
Feb 26, 2010 | Pacific International Pacific Laser...
Measuring Tools & Sensors Logo
67 people viewed this question
Top Laser Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Laser Measuring Tool and Sensor Expert? Answer questions, earn points and help others
