Hi i need to decrease my channel what should i do
I have a panasonic th42px60u my problem is that none of the controls work xcept the on and off volume is on but unable to increase or decrease the volume.
Hi Daniel,
May I know if the remote control is working fine except from the front panel's volume and channel button key?
Nov 23, 2011 | Panasonic Televison & Video
Unit repeats and enters number twice or three times. Also runs past channels when scanning.
Hi. To resolve the repeating command issue, you need to decrease the repeat setting for the device in the Harmony software. The following article by Logitech will assist you with doing this:
Hope that helps :)
Aug 14, 2011 | Logitech Harmony 890 LCD Remote Control
How do you balance sound between two speakers. Where is the balance control? JVC RX5000v
On the front panel ONLY:
1. Press ADJUST so that the MULTI
CURSOR up/down buttons work for
adjusting the sound.
2. Press MULTI CURSOR up/down
repeatedly until "BALANCE"
appears on the display.
3. Press MULTI CURSOR left/right to
adjust the balance.
• Pressing left decreases the right channel
• Pressing right decreases the left channel
please rate my solution.
Jul 04, 2011 | JVC RX-5000V 5.1 Channels Receiver
My SHARP TV 21A-S3 Model and remote model G0002SA. How to decrease screen from remote. please i need its procedure. (cricket score not display in bottom side)
go to menu options. and change your aspect ratio or zoom options. if its only doing it on this channel then its that channels broadcast signal. let me know if i helped.
Mar 17, 2011 | Televison & Video
I have set up a BOSE Accustimass System with my STR de485 receiver. How do I adjust the treble/bass?
if u are using bose speaker system then remember one thing. go to speaker setup and select all the speakers as large not small. then only u will get a good tone. bose speakers will handle the output power of ur amplifier.
u can only adjust the bass and treble of ur frond Channel speakers. for that
select multi channel surround sound and the increase and decrease the bass and treble
Dec 31, 2010 | Sony STR-DE485 Receiver
I have a uniden GMR1448 Two-Way Radio. Both handsets work but they cannot talk to one another. They used to work fine. They are tuned to the right channel and I did everything that I find obvious, like sub...
Check whether the channel and the sub code are same?If this is not same it will not work.
Put the sub code to off.Follow the below steps
1.Press chan tone/scan in channel select mode.The subcode indicator will flash. 2. Press the UP arrow  or DOWN arrow key to increase or decrease the code number displayed.You can also select oF (OFF) at this stage. 3. Press chan tone/scan to exit the Menu.
Thank You
Nov 16, 2010 | Uniden GMR1448-2CK Two Way Radio
Having bad feedback on amp when i use my senniser ew 100 system and loose volume
You can try to decrease the output from the EW-100 receiver on the back.
Aug 16, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
My Harmony 890 remote has a difficult time inputing numbers
Hi. This problem is caused because the 'repeat' setting on the device that you use to change channels (TV or cable box) is too high.
1. In the software, click 'Troubleshoot' next to the icon for the device that you change channels on.
2. Select '<device> responds to some commands either too many times or only occasionally' and click NEXT.
3. Decrease the setting by one (the default is usually 3).
4. Update your remote and test it.
Apr 25, 2010 | Logitech Harmony 890 LCD Remote Control
Loud distortion on Front Channels
Well, the nice thing about the newer amps is that the actual amp circuitry is all contained in a module and you don't have to do much troubleshooting. Just replace the module for that pair of channels. Bad news of course is the modules can be pricey. Should say right on it the part number, order it from or whoever, solder it in, use new conductive grease (many times I think these modules fail because the grease gets old, the module overheats and toasts) and you should be fixya'd
Jan 12, 2008 | Marantz SR-5200 Receiver
Televison & Video Logo
Top Televison & Video Experts
