Question about Intel Computers & Internet
Re-image a Intel Compustick STCK1A32WFC when "A bootable device has not been detected"
3 Suggested Answers
SOURCE: hai sir iam using in intel d945gcnl desktop is
If it displays a message saying "A bootable device has not been detected " Please check that the IDE Cable from the CD-ROM is connected Firmly to the IDE Header as displayed above and also check whether the ATA cable from the Hard Drive is connected to the Serial ATA Header Firmly.
"If you are using two optical drives be sure to check whether Primary Master and Slave are configured properly using the Jumper" If you are using one CD-ROM don't consider about this.
Posted on Mar 03, 2011
  • 4961 Answers
You probably have a mbr virus.
Download The following iso listed below. It is the latest version of the Kaspersky rescue disk. You need to burn it to a CD with a program like Imgburn (Which is also FREE like the iso file). Then you need to boot from the CD and run the scanner. It should fix you right up.
Kaspersky rescue cd download:
Imgburn download:
Posted on Aug 18, 2012
How to restore image by using bootable usb oc dvd
I prefer installing/upgrading the operating system on the ix104c2 with a USB flash drive and the program "WinToFlash" and set the "Hard drive priority" to whatever flash drive you are using as the first boot device in BIOS. I recommend using a USB key board to navigate BIOS and it is required to install the Operating system.
Dec 18, 2013 | Xplore Technologies Xplore iX104C2 Tablet...
Pxe-m0f : Exiting intel pxe rom
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Feb 19, 2012 | Acer Computers & Internet
Your system is trying to boot to a Network Boot (PXE Boot is the way corporations image systems on the network with a corporate image) most likely this is due to the hard drive in your system failing and not being detected as a boot device (PXE boot is normally set as an option to boot after trying the hard drive then the optical drive)
You can try re-seating the hard disk drive then resetting the BIOS defaults and see if the hard drive is detected and boots, if that fails, then most likely the hard disk drive has failed and you will need to replace the drive, then re-install Windows, all drivers, and all applications.
Sep 10, 2011 | Acer Aspire One PC Notebook
Bootable device is not detected
The hard disk has died, replace it and reinstall Windows.
Jun 04, 2011 | Intel D946GZIS Motherboard
Check cable connection! exiting intel PXE ROM. no bootable device-- insert boot disk and press key
It sounds like the BIOS is not detecting the HDD/Windows. If this happened w/out any settings changes, it's very likely a bad HDD.
Mar 25, 2011 | Acer Aspire One PC Notebook
Hai sir iam using in intel d945gcnl desktop is propleam (a bootable device has not been detected)wihch propleam in intel board
Do you have multiple hard drives in your system. In the BIOS select the first boot device and select the 2nd HDD as first boot device.
to get into the bios press del and then use cursor keys to highlight boot tab and then select first boot device as HDD. Use the hard drive boot priority menu to select appropriate HDD as first device to boot.This option is only valid if you have two or more hdd's else your OS is corrupt and you will have to reinstall windows. Even check if all the cables to your HDD are tight, you will have to open up the system , if the system was moved around the cables might have become loose and just have to pushed in well.
Mar 03, 2011 | Intel D945GCNL Motherboard
A bootable device has not been detected in Intel 945GNT motherboard
solving of problem of a bootable device has not been detected. Please refer to the product guide at
Feb 17, 2011 | Intel D946GZIS Motherboard
Emachine NAV51 won't start up. It keeps showing this: Intel UNDI PXE_2.1 (Build 082)_Copyright(c) 1997-2000 Intel Corporation_For Atheros PCIE Ethernet Controller_V2.0.0.9 (05/08/09)_Check cable...
Long answer:
Your computer tries to "boot" from various devices:
* the 'A:' diskette drive
* the CD-ROM drive
* a bootable image on a USB memory-stick
* via the network-adapter, if there is a "boot-server" somewhere on your local network.
So, enter BIOS SETUP, and check that your disk-drive is one of "enabled" boot devices. Also, check that the disk-drive is "detected" by the BIOS.
If your disk-drive is not connected, or not responding, and there is nothing in the 'A:' drive and nothing in the CD-ROM drive, then the PXE (Pre eXecution Environment) will try to "talk" to a boot-server on your network. If no such server is found, you get the "check cable connection" message, and you are prompted to put some "bootable" media into the 'A:' drive or the CD-ROM drive.
Short answer: your disk-drive has "died". You need to replace it, and to install Windows onto the new disk-drive.
I hope that you recently made a good "backup" of all your data files!
Oct 20, 2010 | E-Machines eMachines Desktop PC
A bootable device has not been detected.
Please refer to the product guide.
Jun 15, 2009 | Intel D946GZIS Motherboard
Computers & Internet Logo
47 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
