Question about Dishwashers
Top draw does not drain - Dishwashers
2 Suggested Answers
  • 3247 Answers
SOURCE: top draw beeping delay and water not draining
Not sure what you mean by beeping "delay" I am not sure if there is any such light on the dishwasher. The HRS DELAY is displayed on the LCD when dishwasher has been set in delayed start mode. Are you seeing this flashing in an orange background? There could be several reasons for water not draining. Does the beeping go away if you press the power on/off button? Also does the delay flashing stop. Have you checked to see nothing is blocking the drain pump which is the same rotor that drives the washer arms.. What about the kitchen down pipe - is it clear? If you think you have to take the drawers out to reach the drain hose then follow instructions on page 7 step 2 of the installation manual. It is for a later model but your one should be similar. Make sure you turn the mains power off when working inside the dishwasher.
Posted on Jul 08, 2010
F& P bottom dishwasher draw won't drain. Top dish draw draining fine?
Excess water in
the DishDrawer
Drain hose(s) bent or
kinked.
Straighten the drain hose(s).
Blocked filters and/or drain
hose(s).
Clean the filter plate/drain filter. Unblock
the drain hose(s). Refer to the user manual
Aug 28, 2014 | Fisher and Paykel Dishwashers
Fisher paykel DD609 diswasher - top draw does not drain properly. Water build up in bottom of the top draw even when bottom draw is used.
It is usually due to a small piece of broken glass or plastic blocking the little propellor that pumps the water out, (think of the little paddle in Nemo's tank)
You need to remove the bottom of the machine, undo one screw and twist the pump free, fairly easy, but make sure you turn the power off first. The outlet hose and pump will then be accessible, have a look in and turn the paddle with a screwdriver, bet you will find something blocking it. Shake it out and reassemble
Mar 22, 2008 | Dishwashers
FDB1050REC2 no water
If water runs back into the drain then your drain hose is not properly afixed to the top of the unit under the cabinet. It must be at the top of the unit so no more than a half of an inch of water falls back into the tub when finished.
Dec 26, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
WHEN RUNNING A CYCLE ON TOP DRAW THE BOTTOM DRAW WILL FILL UP WITH WATER NOT DRAIN
The drain hose going to the kitchen sink is blocked. If you have an insinkerator in your kitchen sink then run it first. Otherwise take the dishwasher hose out from the sink outlet and run straight into sink to see if any difference.
Aug 17, 2010 | Fisher and Paykel 23 in. DD603H SS...
Have a rental property with F&P two draw dishwasher aprox five years old. Apparently bottom draw is holding water - what do you think?
Could be many reasons for the bottom drawer to hold water.
It could be leaky top drawer causing water to collect in the bottom drawer. Check if water collects when top drawer is running.
It could be blockage in the bottom drawer drainage which can be fixed by cleaning the filter plate and the drain sump. If the drain pump is not running during drain cycle then you will have to replace the drain pump motor.
Aug 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top draw beeping delay and water not draining
Jul 06, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
Softener slot won't drain.
take the soap draw out there should b a sign on the draw to press also the top of the sofner compartment comes off u will see a hole where the water goes make sure it is clear put the lid back on hold soap tray under water tap let the water fill the sofner compartment it shoud run out
Aug 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Double dish draw
removed filter, removed rotor, check for obstructions in sump. If problem still exists physically check drain hose for restrictions/kinking
Jul 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dd601 ver2
have you check the tunnel between the kidney shaped sump and the well that the rotor motor locks into, often chips of crockery,seeds etc get caught in here and reduce the flow rate .You will need to remove the rotor motor,its easy, lift out racks then sprayarm to expose rotor motor turn locking ring to release stainless sieve lift out, then turn motor assembly anti clockwise and lift out.With something flexible eg 4mm insulated wire push it through tunnel from sump to motor well.
Jun 21, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
DD601ver2
check for restriction in sump. ie remove rotor, push pipe cleaner or similar from filter sump into rotor sump
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
Owen Barnes
