Question about Craftsman Garden
Engine want turn over on a riding mower why?
Craftsman riding mower 18.5 HP the engine was running good at idle it made a bad noise and cut off so i remove the spark plug and use a pull handle and socket on the engine pulley and try to turn the engine it did turn just a little i put a screw driver into the plug hole but i never felt the piston move what could have happen?
    An user who is expert in 3 categories / brands.
  • Craftsman Master
  • 924 Answers
If the engine will turn but you are not feeling the piston move up and down the connecting rod is broken. buy a new engine.
Posted on May 10, 2017
  • 109 Answers
In the back of the mower...probably under the seat, there should be a lever to release the transmission, or it is on the back plate. As far as the noise when trying to move drive the mower, the brake in the back, next to the transmission is jammed, use a 1/2 inch wrench to loosen it maybe 1/4 turn and this should unlock the brakes
Posted on Apr 22, 2009
  • 513 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 1305 Answers
SOURCE: Craftsman mower with 20hp B&S Intek won't start/run
That throttle cable issue sounds like it may be the culprit. the cable housing (the outer casing for the wire throttle cable) may not be anchored correctly. Which may be allowing you to move the throttle without any change at the butterfly control on the carb. make sure the cable housing is anchored at both ends.. by the throttle control and at the carb area.. That may be your problem... hope it is that simple...
Posted on Jul 23, 2009
  • 52 Answers
SOURCE: Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
Posted on May 02, 2010
SOURCE: craftsman riding mower will not start
Same thing happened to me with my 26 horse kohler craftsman. Replaced EVERYTHING (spark plug, fuel filter, oil filter, and degunked the carborator), and still was flooding. It ended up being the flywheel key. Cheap part, quick fix. I guess it can happen when you hit something hard with the deck, or it can just happen without reason... I hit a snowbank hard with my snowblower attachment, but I didn't even realize it until afterwards because it kept running fine. Supposedly, even after the strain to the engine, it won't always stall out. It will keep running (but maybe rougher) until you shut it off. Then when you go to start it again, you will have no luck because all the timing is out of whack. It cost me $80 to have a repair company fix it. I think the part was only $5.
Posted on May 21, 2010
18 hp craftsman 2000 smokes when cutting on a side hill
Wanda, make sure oil is not over full, oil in crankcase could be running to the intake of carb., valve guides or piston drenching an excess amount of oil on them causing the smoke. As long as mower does not smoke when driving on near level surface, mower should be OK. These engines were really not designed to cut on steep grades.
2 stroke engines, the engines with gas/oil mix are the mowers that are safe to run on hills as they will not starve or over lubricate engines. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
smoking at an angle
white smoke coming from riding lawn mower exhaust ShopYourWay
Jul 29, 2016 | Craftsman Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ... > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from
Dec 29, 2015 | Garden
I have craftsman 18 hp run 20 min get hot cut off change coil
Be sure fins are clean. Its around spark plug. And engine clean.
Jun 19, 2014 | Craftsman 18.5 HP 42"
I have a snapper riding mower with 11 hp b&g engine what is the setting for the low speed idle screw
would this screw be a stop screw on the throttle. because if it is the farther out you turn it the slower the engine will run.if this is not the case would you please email me personally and i will guide you through the steps for the othe screws...good luck
Mar 27, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have an 18 HP Craftsman tractor (model 917255980) that will not start. If i remove the fuel line from the carb, gas does not run out freely, hoever, by applying suctin on the line gas does flow breifly....
The pump is not good,to test it,you take out the out fuel pipe start the engine ,see if fuel is coming out fully to the pipe,if sometimes it comes and cut,this means the fuel pump is not working properly.You have to change it.
Sep 06, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Stalls when put in gear or engage mower
your lacking power and probably need to clean your carb or adjust the main idle screw..its on the botton of the float bowl...back it out a half turn...start with a quater..well its running
Jul 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
