Question about Sterling Home
Like to know the height of 17 55 3 2011 Pop Top Sterling Van. Measurement from GL to top of toilets plastic cover (with Pop Top extended open) Thank you
SolutionGuy
  • 331 Answers
SOURCE: Disassembly: "Pop the top up and raise it ..."
Greenjeans, pull the dryer out and look behind it at the top panel. You'll see 6 screws, 3 in the panel, 3 going into the cabinet. Remove the 3 that go in the cabinet. Then slide the whole top panel back (away from the control panel) about an inch or so then lift it. Replacement is the opposite of removal.
Posted on Oct 06, 2007
  • 18 Answers
SOURCE: hp deskjet5650
When closing the cover very slowly do you feel at the very bottom before it "closes" a slight resistance?You should have to push it down to finish the movement. Simply let the lid rest on your fingers and lower it into place, if there's no resistance just at dead bottom then the physical tab attached to the pegs of the cover may have broken off. The swich to "close lid" is probably internal by the lid joint.
Check to make sure the print carriage isn't snagged either. any little piece of anything can cause problems.
Good luck.
Posted on Oct 26, 2008
  • 8 Answers
SOURCE: Bernina 730 Can't open top cover !
The problem is that of a stuck piston detent on the pattern selector support that snaps the top cover closed.
  1. Open the light cover
  2. Apply pressure with thumbs on the bottom edge of the top cover on both the right and left sides of the cover. The cover should pop up...Too much pressure on the left side, (if this thing is really stuck) and you might break the top cover at the thread tension slot. Be careful here....
  3. Add a drop of acetone (fingernail polish remover) to the piston detent and work it free by pushing it back and forth. Avoid getting any acetone on the painted surfaces of the machine.
  4. Continue to work free, repeating with a few drops of acetone, and wipe clean. Don't oil this part. It was a petroleum product combined with a galvanic process (aluminum and steel) that caused the problem in the first place, not to mention age.
  5. Use DTE Heavy Medium oil rather than a white or clear oil when you lubricate your machine. White oils are unstable and will oxidize (decay) much more quickly. Also avoid 3 in 1 oil and stuff like WD40....very bad....
  6. Oil 1/2 a drop on those prescribed areas. Too much oil is more harmful than not enough....
  7. Contact your Bernina dealer for this oil.
Posted on Sep 06, 2009
Testimonial: "To swiss_tech Great help. Very much appreciated. Thank You"
  • 35 Answers
SOURCE: Says can't print because top cover open when it's
this is the common problem of 5150 printer .you just open the top cover ,in your right hand you can see a black moving part it may not working properly. try to move back and forth many time ,then close and check your printer.
Posted on Feb 16, 2010
  • 9 Answers
SOURCE: Pitney Bowes FD40 Folder Top Cover
did you fixed your problem with the folding machine??
Posted on Mar 18, 2010
I am currently doing a carburetor rebuild on my yamaha and I am trying to adjust the float height, but I am having trouble finding the clearance
this is a rule of thumb for carbies where the float is pivoted from the top cover
with the float in position turn the top upside down and the float will now be in the position it is in when controlling the fuel
the float top should now be close to parallel to the top cover it is attached to
if you manage to get a measurement for that distance it is measured by the specified measurement as a twist drill and it is to move under the float as you roll it along the top cover
not to move it up or miss it but just touch it
adjustment is by bending the small tang that is connected to the needle
now if such a measurement is not available simply ask your service dealer what it is
May 13, 2016 | Yamaha Virago Xv 535 Xv535 Engine Cover...
How do I adjust the fill valve on a Jaccuzzi Era toilet?
If it resembles a Fluidmaster unit, twist it clockwise to decrease the float height. You may have to flush and recheck the setting to get it just right.
Jul 20, 2017 | Jacuzzi Bath Era BK37 959 White toilet...
Where do you get the overall height measurement at
3 measurments here
*static height-
*dynamic height-
*suspention height(extended fork length)
static height is measured with a plumb line to the ground at the center of the fork tube top with the motorcycle standing upright and no rider on on it
*dynamic height is the same except your sitting on the motorcycle.
*suspention height /extended fork length is with the front wheel off the ground and measured from the center of the front axle to the top of the fork tube.if tube cap/valve is recessed you still use the top of tube measurement but if it has a cap that screws in on top of the tube then imagine the fork cap removed (measurement stops at the top of tube itself.(most always)
Mar 01, 2012 | 2004 Honda VTX 1300 Retro
It will not flush properly .rudy
How to Troubleshoot a Flushometer
A flushometer consists of a metal pipe extending from the back of a toilet with a slender handle on the side that is used to flush a toilet. This type of flush valve is commonly used for toilets in commercial facilities to provide a durable and accurate flush delivery system. If the flushometer does not work properly, troubleshoot it and perform minor repairs. Common issues are often resolved quickly. If troubleshooting does not correct the problem, call a plumber for repairs.
Does Not Flush
1 Inspect the handle assembly. A broken handle or assembly will prevent flushing. If damaged, unscrew and remove the handle assembly. Replace the handle or repair it with a handle repair kit
2 Open the main water supply valve to turn the water on fully. The water supply is normally turned on, but check to make sure it is turned on fully and has not been turned off inadvertently
3 Remove the flushometer's CP cover, the round cap on the very top of the pipe extending from the toilet. Then remove the inside cover directly underneath the cap. Inspect the relief valve. Replace it if it is visibly damaged.
Short Flush
1 Remove the CP cover and inside cover. The CP cover is located on the very top of the pipe extending from the back of the toilet. The inside cover is underneath the CP cover and the diaphragm assembly is located beneath the inside cover. Remove and inspect the diaphragm assembly. A damaged diaphragm assembly can cause a short and incomplete flush. Replace it if it is visibly damaged.
2 Replace or repair the handle assembly. A damaged handle can result in a short flush. If damaged, unscrew and remove the handle assembly. Replace the handle or repair it using a handle repair kit.
3 Remove the CP cover and inside cover to remove the diaphragm assembly. If a low consumption diaphragm is installed on a water-saver fixture or a urinal diaphragm is installed on a toilet fixture, replace it with an appropriate diaphragm.
Mar 04, 2011 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
My toilet is moving-how do I get the covers off the floor bolts
The covers are 99% of the time plastic, and if broken will cost around $3 to replace if you break them.
The caps are a two part systema base that goes below the nut and the top dome that covers the assembly. See here: http://www.plumbingsupply.com/images/toilet_bolt_caps_green.gif (ignore the special color)
These two pieces snap together and with a slotted/flathead screwdriver should just pop off with a little bit of convincing. If they are too loose that the screwdriver will not work a claw hammer can also pop them off. If all else fail, break them. They serve completely aesthetic and no actual function beyond, however they are easier to clean and may assist in the reduction of bacteria growth.
Feb 04, 2011 | Kohler Home
Toilet keeps running water in back tank keeps running over top of drain hole
You don't have to replace, You just need to adjust the fill valve. If you have the ball **** type just tight the top phillips screw. If you have the newer type, close the water valve under the tank and Push down a plastic ring at the bottom of the filling valve, Push down the top of the valve, lift the plastic ring to it's place and open the water valve.
Aug 01, 2010 | Toto Home
Toilet flushes 3 times when it is flushed.
take off top cover, and check flapper valve for proper seating when flushing.. could be that it is dirty (where it makes contact with tube of tank), and/or the chain length is too short (one link or two)
May 25, 2010 | American Standard 2002.014 - Champion4...
Home Logo
35 people viewed this question
Top Sterling Home Experts
jmartin50
Level 1 Expert
Tim Whalen
Are you a Sterling Home Expert? Answer questions, earn points and help others
