Question about Acer Computers & Internet
I have an acer aspire E1-531 and I have put an UHS-1 card with adaptor into front slot...nothing is coming up on my screen to be able to access the photos I have on this help
TheBoognish
  • 20 Answers
SOURCE: acer aspire 5920 notebook and the 5 in 1 sd card reader
Open "my computer". The SD should be visible from that window. If you right click on the SD drive and chose "explore" from the drop down list it will open a window so you can access the files inside.
Posted on Jan 28, 2008
MerlinTech
  • 197 Answers
sure...I'd say you need to do a system restore to a previous point, or get new sandisk drivers from their site
Posted on Jun 15, 2008
  • 53 Answers
SOURCE: photo transfer from memory card to acer one laptop
hey! u r stuck to such a simple problem. well not to worry when i'm here.
first of all u check whether ur card is locked??? Check the sides of the card and u will find a small slider, slide it down and then insert into ur card reader.
then open My computer, there u will find written removable drive beside the cd drive or so. open it and u will find ur photos. then single right click on any of the photo, a pop-up menu will appear, select to 'copy' option and then open the drive where u want to paste ur photo, and there again single right click and select 'paste'. and guess what ??? it's done!
hey dude, never forget to rate me!!!!
Posted on Feb 01, 2009
  • 7 Answers
SOURCE: acer not work
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
Posted on May 25, 2009
shynysaxena
  • 166 Answers
SOURCE: How to insert SD memory card into card rader in laptop computer
I would like to inform you that Acer's laptop doesn't support all kinds SD memory cards available in local market. Its not compatible with all physical dimensions of various memory card companies. So in that case you need to use EXTERNAL Memory card reader which is attachable to USB ports.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Posted on Jun 29, 2009
Where is sd slot on computer
The Acer 5315 Notebook doesnt have a SD Card slot to my understanding.
Jan 09, 2013 | Acer Aspire 5315 Notebook
Where is the micro sd slot on my computer
I will bet no. as fare as i can remember theres never been a laptop with a micro SD slot... so you need to get an SD to micro SD adaptor
Jun 10, 2012 | Acer Aspire 5750g-6653 - Core I5 2.4 Ghz -...
Does Acer aspire 5740 support microSD cards?
Yes it do supports the microSD cards, You will need either an adaptor or a USB cable which can connect the device which uses the card to you laptop.
There are a couple of types of adaptor, one basically converts the micro card to and looks like an ordinary SD card. The other looks like a USB flash drive which you slot the micro card into.
Sep 27, 2010 | Acer Computers & Internet
Card slot location on acer 5740-5255? I tried to insert at front of laptop but too big. Do I need an adapter? I am using Scan Disc pro Que
I can't find a Scan Disc pro Que, but I can find a Sandisk Pro Duo, which is a micro SD card.
Really cheap on Ebay. Just search for a Micro SD card adaptor.
Jun 30, 2010 | Acer Aspire 3610 Notebook
Acer Aspire 6920 6-in-1 card reader
put ur SD card in and restart will install all drivers and will make the card reader work
Mar 19, 2009 | Acer Aspire 6920 Notebook PC
I have a TP link wireless adaptor for an acer aspire T180 pc. I can't work out where to fit it on the motherboard
Providing the wireless adaptor is a PCI card this fits the white slot on motherboard.
Should it be USB, then plugs in the USB port.
Feb 22, 2009 | Acer Aspireā„¢ T180 PC Desktop
No display when using bulit in graphic card or AGP grahic card
ok!
first,
check your
motherboard
if all pin is conected properly
check your power suplly
try to replace the power supply
is not necessary to replace the power supply with the original powersupply
replace with standart 350 watt power supply (or higher)
then if the problem is still exsist
check *********** board
try to replace the motherboard
replace it with
any socket 478 motherboard
if nothing change
try to replace the RAM module
replace it with any DDR RAM module
then the last one
if nothing change
you must replace your processor
with an 478 socket processor
note: replace the component with borrowed
you  can borrow the component from your friends or anyone
then if your computer is showing display again
you can buy the component from ebay
here original specs of your computer:
Specifications - Aspire T310
Processor
Intel® P4 Processor with 400/533/800FSB (depending on processor)
Intel® Celeron Processor with 400FSB
Cache
128KB or 256KB (dependent on processor)
Memory
128MB DDR SDRAM PC2100/PC2700/PC3200 expandable up to 2GB
Chipset
SiS 661FX Northbridge Controller,
SiS964L Southbridge Controller
Expansion Slots
3 PCI v2.2 slots
1 AGP slot 4X/8X
Audio
Integrated Realtek ALC655 audio codec (SoundBlaster® Compatible AC97 Audio Codec)
Speakers (selected models)
selected models
Video
Integrated SiS 661FXVGA,
Storage
3.5" 1.44MB Floppy Disk Drive
52X CD-ROM, CD-RW or DVD-ROM (selected models)
20GB-80GB Hard Disk Drive (selected models)
Modem
56K V.90 (selected models)
Networking
Integrated Realtek RTL8100C 10/100 Base T
Ports
1 PS2 Mouse port, 1 PS2 Keyboard port, 2 USB Front, 4 USB Rear, 1 Parallel, 1 serial , 1 VGA, 1 game/midi, 1 RJ45, 5 audio (2 front, 3 rear)
Power Supply
Industry Standard 230 Watt
Chassis
14.2" 360mm) H x 7.1" (180mm) W x 16.5" (420mm) D
Operating System
Windows XP Home
Windows XP Professional
Windows 2000 Professional
Warranty
1-year Mail-in/carry-in warranty, Technical support for first year, available 8a.m. to 8p.m. CST Monday through Saturday (hardware only), 90 day software support. Call 1-254-298-4696
Specifications are subject to change without notice. Warranty covers only Acer purchased parts that are listed as supported and serviced. Please see limited product warranty for full details. Acer, the Acer logo, AcerPower, AcerAcros, AcerEntra, AcerAspire. Aspire by Acer, and Veriton are registered trademarks of the Acer America Corporation and Acer, Inc. The Intel Inside logo and Pentium are registered trademarks of Intel Corporation. Microsoft, Windows, Windows 95, and Windows 98 are registered trademarks of Microsoft Corporation. All other brands and products names are trademarks or registered trademarks of their respective companies.
Jan 24, 2009 | Acer Aspire T310 PC Desktop
Method for opening tower
Hi Bob, you put it into the Compact Flash slot. Do you have a wife ? with make-up tweezers ?? these usually work. no need to take the side panel off, you will not be able to access it from inside the unit.
chris
Dec 28, 2008 | Acer Aspire T135 PC Desktop
Acer aspire 5920 notebook and the 5 in 1 sd card reader
Jan 28, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
