GAF Super 8 projector 3000 is stuck. Film was fine. I turned it off for a minute. Now it is stuck. Will not go forward or reverse.
SOURCE: Downloadable instruction manual for Bell Howell 456 super 8 mm dual movie projector
Posted on Aug 19, 2008
  • 2841 Answers
SOURCE: tractor won't go forward or reverse
Check the drive belt. It has probably broken or has come loose.
Posted on Sep 01, 2009
SOURCE: I am looking for a free manual for the Eumig Mark 8 projector
was there any chance of me getting a free manual or is this site just a money making idea, obviously if it sounds too good to be true..it usually is!
Posted on Sep 15, 2009
SOURCE: Have a GAF 2388 dual 8mm projector. Stopped running
change the fuse
Posted on Oct 22, 2010
  • 412 Answers
SOURCE: Projector works fine, but will not advance slides.
Try a different tray (preferably a Kodak 80-slide tray). If it works, then the problem is a tray problem. If it makes no difference, check the "SELECT" function. If that works, then your projector requires an adjustment to the slide change mechanism. If it does not work, remove the tray and push the "REVERSE" button 4 or 5 times (this will clear a mechanism jam if one has occurred). If you still have nothing, then chances are that the slide change mechanism drive belt is broken or stretched. try the diagnostic things I suggested. If they are no help, I'm sorry to say you need the help of a factory-trained repair dealer. Good Luck !!
Posted on Jan 30, 2011
How to load and view with a gaf 2388 projector
Usually there is a series of clips or levers of some sort that allows the film to pass around the sound drums and alignment path behind the projector lens. There is usually a line printed inside the projector to show the thread path for the film around the various mechanisms. But before you do that you might want to consider finding a photo shop that converts the film to a CD format. All of the old film media breaks down over time and you may be able to enhance it, preserve it and avoid burning it up in the projector(a common occurrence in those days) all at the same time.
Apr 29, 2015 | Cameras
I need a description for this item
This is a movie projector for 8 MM Film and Super 8 MM film (That is why it is called 'Duel Eight". Does it have a 'Volume Control' knob for sound film? If not is is just for silent film. Does the light come on when turned on and film engaged?
Mar 08, 2015 | Miscellaneous
The film stuck when I feed it
This is a common problem with these projectors. Usually happens after a film breaks or a bad splice goes through it. Pull the lens straight out and then remove the lens housing that holds the lens and the focus controller. The screws for the housing are behind the glued on cover that says frame and focus. Remove the 4 screws behind it, slowly lift the cover and watch for a loose leaf spring that sits behind the cover. It will fall out if the projector is standing up, so lay it on its back and it will just sit there so you know where to put it during assembly.
Mar 26, 2013 | Canon Ps-1000 Canosound Super 8 Projector
THREADING FILM IN A ELMO FP-C PROJECTOR
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm.
Jan 10, 2013 | Sewing Machines
HAVING TROUBLE THREADING FILM - ELMO FP-C
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm. If your green lever is stuck in the forward position, that's because the film is not threaded. Once your film threads correctly, the green lever will spring back.
Bell & howell 356 projector runs slow
You have this posted in the car and truck forum, please re-post in the correct product category.
Feb 21, 2012 | Cars & Trucks
Belle & Howell Super 8 Projector model 254RS loading problem
Don't have the motor switch in the still position when loading -make sure it is on FORWARD. Look at the little holes in the film and make sure the film is on the same side as the little grooves on the drive gear.
PS -let the bulb cool off before try to move the projector ,the bulbs are very expensive and hard to find.
If you do use the still position to view a frame do it for just a few seconds or the bulb will burn the film. Good luck- Tom.
Jun 21, 2008 | Bell & Howell Photography
May 20, 2008 | Photography
27 people viewed this question
k24674
