Question about Refrigerators
My Jenn Aire refridgerator, the refridgerator compartment is 15 degrees which freezes the water line to the ice maker.Where is the thermostat that controls this.
The Model # is JCB2059GES, Mfg. # RJCB2059GSO, ser. # 10840483AT
SOURCE: Whirlpool refrigerator Model # ETIRHMXKT
can be worn gaskets...clogged pipes or coolant leakage.
tell me about
Posted on Jun 22, 2008
  • 1122 Answers
SOURCE: jenn-Air Refrigerator JCB2059GES freezes
your thermostat is bad,get the model number from inside and call your local appliance store and get a new one,let me know,thanks-mike
Posted on Jun 23, 2008
SOURCE: JENN-AIRE MODEL JCD2389GEW = WATER/ICE
defros heater
Posted on Oct 18, 2008
  • 51 Answers
SOURCE: water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Posted on Jan 09, 2009
  • 1169 Answers
SOURCE: GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Posted on Apr 20, 2009
I have a sub zero model 650 refridgerator. It is making some ice then it seems as though the water keeps dripping and it freezes up the shelves. Its like the water doesn't shut off when its suppose to...
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Refrigerators
We have an ice glacier building up behind and below our ice maker inside our Jenn Aire side by side refridgerator model JRSD 2450.
WATER LEAKS ON YOUR WATER SUPPLY CONTAINER TO THE WATER DISPENSER OR CONDENSATION PROBLEM RELATED TO FRIDGE DOOR FAULTY SEAL
Nov 09, 2010 | Jenn-Air JCD2389G Side by Side...
Jenn aire refrigerator not completely freezing ice cubes
Increase the inside coldness by rotating the termostat switch nob to a higher number position.
Oct 03, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jen Aire Fridge ice maker fingers are below the
This one you have to take out the ice maker and run hot water from the kitchen sink into the tray to get the ice out. need model number if you want detail explaination how to. or just use a hair dryer that will work to!!! if fingers dont rotate after defrost ice then the gears are stripped, replace ice maker
Mar 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Give-me plis a wiring digram manual of the Ice Maker U-Line BI-95
Your going to call U-line and ask for it. 800-779-2547. Now what are you trying to do? I can give you the wires on the thermostat. Terminal 1 is red(icemaker) Terminal 2 is yellow(common) Terminal 3 is blue/black(compressor and cond fan motor) When yellow and blue or black are closed this will run the compressor and fan.Thermostat is satisfied then the red and yellow are closed and it advances the icemaker. Ejector blade at the 12 oclock calls for freeze cycle. at 2 calls for heater to come on(inside icamaker) at 10 oclock it trios the water switch and calls for water.Then back at 12 oclock calls for freeze cycle. Temps should be 10-15 degrees in the bucket. Warmer the setting the more ice it makes.
Jun 30, 2009 | U-Line BI-95
Ice maker not completing cycle
You need to check the thermostat setting. If its set too cold it will never dump ice. Warmer the setting the more ice it will make.Also check the temp. If it should be 10-15 degrees. If its 5 degrees then turn thermostat to warmer setting.
May 09, 2009 | U-Line Icemaker
Jenn-Air side by side won't give water
hi thanks for the question yes the small tube that enters the ice maker can freeze up stopping the water flow check this thanks the appliance doc
Sep 16, 2008 | Jenn-Air JCB2280HES Side by Side...
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
