Question about Garden
Have a M108S tractor ,the lift arms will not raise
5 Suggested Answers
mattofilms
  • 110 Answers
SOURCE: '07 5403 John Deere Tractor lift arm will not lower
some-times the 3pt linkage can go past the top position.
When this happens - you will need to force! the linkage arms down.
Posted on Jul 02, 2009
  • 520 Answers
SOURCE: i Have a massey furgeson 135 and the back arms
below are just a few of the tractor forum sites i use. these guys are really helpful and someone will have the answer for you. all i can say is to make sure all your levers are in the right position and check the quadrant lever position on your right.
http://forums.yesterdaystractors.com/viewforum.php?f=19&sid=419bda8adfabe7c0757a89cd5e57d483
http://www.ssbtractor.com/wwwboard/Massey_Ferguson_tractors.html
http://www.mytractorforum.com/showthread.php?p=1391397
Posted on Oct 05, 2010
SOURCE: I have a lawn mower
Larry,
I have a Troy built x20 lawn tractor and the lift cylinder moves until the weight of the blade is on it and then it stops. Sounds like we have the same problem. Any luck with yours? ANy answers out there. Again, the cylinder will move raise and lower until the weight of the blade is applied. The left to right cylinder will move but very slowly. Any ideas from anyone would be appreciated.
Tim
Posted on Feb 07, 2011
  • 2992 Answers
SOURCE: How do u fix lift arms that are stuck on a 7200 John Deere tractor
Owner's manual or service manual from
http://www.manualslib.com/
Posted on Mar 09, 2015
Is there a way to operiate the hydro to raise and lower with out the PTO spinning
If your tractor does not have "live pto", then neither the pto shaft, nor lift arms when the clutch is depressed.
I don't think any 2n's, 9n's, or 8n's came equipped with a live pto.
Hope this helped.
Jan 23, 2011 | Ford 8N Tractor
I have a lawn mower that has a hydraulic lift - and frequently it will not lift the mower deck or snowblower unless I push down on the lift assembly arm (it is connected to the mower by chains) while I...
Larry,
Tim
Dec 17, 2010 | Garden
LIFT ARMS FOR 3 POINT HITCH WILL NOT MOVE, NOT SURE WHAT CONTROLS OPERATE
Standard tractors have a lever to the right of the driver, move toward the rear of the tractor to lower ... move toward the front to lift.
May 07, 2010 | Garden
How to adjust the mower deck on my murray rider,
Park the tractor on a firm, level surface. . .
At the lower end of the lift/lower travel slot, there should be a plastic cover which you pop up so that your blade lift handle goes all the way down (it should say something about blade level on there somewhere. . . . .
After you have the handle in this position, look at the front lift arms of the mower deck and find the 2 large wing nuts, one on each side. . . . .
Loosen these while the deck is down and then retighten them Your deck is now level and will lift to its highest recommended position when you raise the lever
Oct 11, 2009 | Garden
Apr 05, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Deck Height Adjusting
you should have holes on the arms of the adjuster look for the most worn hole that is where the studs should go
May 23, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
