Tried that. no luck. - Computers & Internet
Magnavox tv , when turned on the volume goes to cero by itself and control wont work on it
Make sure the batteries in your remote are new. Unplug the TV power for about a minute. Plug TV power in. Turn TV on and try remote again. If no luck, make sure no other IR devices are in the room and turn off any lights and try again. If no luck, try a new remote. If no luck. your TV may need to be serviced.
Sep 21, 2017 | Magnavox Televison & Video
Fix a HP DV5200 that will not boot
faulty CPU most likely. take the CPU out and get a replacement from EBAY etc. get some isoproyl alcohol and some thermal paste from there too. warning: you will need to reformat your hard drive as the BIOS settings will most certainly be different and you will probably get the BSOD (blue screen of death) by trying to cold reboot from the same hard drive. back everything up first. take the hard drive out and get a caddy and backup to another machine.
Mar 07, 2012 | Pavilion DV5000 DV5100 DV5200 Series...
My DVD burner disappeared from my computer. It is listed in the device manager and has no problems.
Go to device manager and uninstall the offending hardware. I had the same problem running Windows 2000 with dual DVD burners. They both stopped working and I tried unplugging them and rebooting-no luck. Tried fooling in the BIOS - no luck. Tried reinstalling the drivers - no luck.
The uninstall worked! After a reboot, Windows found the drives and installed them
Feb 04, 2011 | Mach Speed (MSNV-939) Motherboard
Offline
try open ur handset and make the pcb warm with ur hairdryer and fix it again i think it is due 2 moisture and it should work as its not picking simcard.try it and reply me with results.
Jul 12, 2008 | Nokia 6630 Cellular Phone
Laptop
sound like a bad motherboard
Jun 26, 2008 | Computers & Internet
Razor v3xx locked, default code changed, too.
just take the phone and have to a mobile service center in your area and have them reset the phone to it's default for you.
Apr 07, 2008 | Motorola Mobility RAZR V3
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
