Question about Poulan Garden
Which oil weight for Poulan 6.5 HP self propelled lawn mower
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Poulan Master
  • 975 Answers
10 w 30
Posted on May 10, 2017
What type of oil do you use for 6.5 hp yardman lawn mower mtd 160cc 21 inch self propelled
The manual will call for 30 weight, but 10w30 works just fine. Be careful to not overfill the crankcase. Your machine will take 16 - 18 oz's when the crankcase is empty.
Tim
Oct 06, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I evidently put too much oil in the Proulan Pro Lawn Mower. Now I cannot get it started. It sputters at first but will not start. I have cleaned off the spark plug with a paper towel and sand papered the...
First thing is to remove the excess oil. Take out as much as you need to to get to the line on the dipstick. Next, you may want to use a little WD-40 or similar cleaner to spray into the spark plug hole to thin the oil in there. Replace the spark plug and start the machine a number of times until it runs correctly. Using WD-40, remember the term "little". Good luck...Lee
Jul 22, 2010 | Poulan Pro 22" Self Propelled High Wheel...
I don't know what oil to use.
20 oz.
sae 30 weight oil,brand name automotive oil will be good
May 28, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Where is the oil drain plug? I have a Poulan 600 pro self-propelled lawn mower and cannot find the oil drain plug to change the oil.
It is on the bottom of the engine. Lift up the deck and look under it. Make sure there's no grass covering it up.
Apr 22, 2010 | Poulan Pro " Pro" Self Propelled Mower
My Poulan self propelled lawn mower model 961320048 is leaking oil from the bottom after use. I cannot find the oil drain plug to tighten it. Where is it located?
where is the oil on under there ??if it's on the shaft where the blade attaches the the oil seal is bad...that's caused by old oil, which is too thin and seeps out...try changing the oil first...
this will help...copy & paste...
http://www.youtube.com/watch?v=XXvsdWbW5D8
Apr 18, 2010 | Poulan Pro 22" Self Propelled High Wheel...
How to change oil in poulan 22 self-propelled mower
there should be a drain plug under the mower near the shaft that the blade is connected to... good luck
Apr 07, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Where is the oil drain plug for a poulan self propelled 22 inch 625 series mower
remove spark plug wire from plug,tip machine on its side.look under blade for a threaded plug with a square head where bottom of motor protrudes through deck.on most models you can simply tip machine over far enough to allow oil to drain out the dipstick[filler]tube.
Sep 27, 2009 | Poulan Pro " Pro" Self Propelled Mower
Poulan Pro® Self-Propelled Mower
Make sure the engine is not overfilled with oil most of the small rotary mower engines hold about 20 oz of oil.It will push oil out of the breather is the oil level is too high or if the mower was tipped on its side. Also check the air filter to make sure the oil did not saturate it.Once you correct the problem the smoke should clear up.
Aug 05, 2009 | Poulan Pro " Pro" Self Propelled Mower
Garden Logo
49 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
