Question about Rotary Drills
The hammer part of dynalink rotary drill stopped working
  • 2712 Answers
SOURCE: hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Posted on Aug 27, 2008
comax
  • 154 Answers
SOURCE: i have a bosch rotary hammer 11245evs and it was
They are filled with a special grease that comes from Bosch. It sounds like the impact bolt or the striker pin in the unit are not moving the way they should. These are the pieces that work together to create the hitting action. About all that can be done now is the unit has to be dismantled to get those to pieces moving again. Bosch makes what they call service packs for all thier hammers. They have all the o-rings and grease to get your hammer working again. A Bosch service center can supply you with the kit. Ask for P/N 1617000225, or they can take care of it for you.
Hope this helps
Posted on Apr 16, 2009
  • 5 Answers
SOURCE: rotary hammer won't rotate, hammers very good
If tool hammers brushes still good. Motor runs hammer action.
Take hammer/ drill switch lever off by removing small plastic plug in center with small screw driver.remove indicator handle off by removing #8 torx screw and lightly pry off. There is a pin and spring that lock tool into hammer or drill.Check for broken spring or binding spring and pin.If binding , clean and grease.
Posted on Jul 08, 2009
  • 211 Answers
SOURCE: Bosch GBH 2-20 SE hammer drill stopped working
hi
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
Posted on Dec 16, 2009
rowdy45176
  • 2176 Answers
SOURCE: i have a makita hr300c rotary hammer drill.
it sounds like it needs new o rings and serviced. you can go to Makitatools.com and download a breakdown for this tool, If you are handy and take your time they are not that bad to repair. Let me know if you need more assistance.
Posted on Mar 21, 2010
I have a black and decker rotary hammer drill i can only read 3 numbers of the model it is 045 but its the last three sn number 0481121 under pat 3309541 need parts manuel for
Your one sounds like this one
http://www.ereplacementparts.com/black-and-decker-5045-type-100-rotary-hammer-parts-c-4167_7879_17406.html
However there are three variants on this page.
http://www.ereplacementparts.com/black-and-decker-hammer-drill-parts-c-4167_7879.html
Black and Decker Hammer Drill Parts ' Great Selection ' Great Prices ...
  1. Cached
  2. Similar
Black and Decker 22738 Type 1 1/2-Inch Hammer Drill Parts. 22738 Type 1 Black ... Black and Decker 27106 Type 1 3/4 Rotary Hammer Parts. 27106 Type 1 ...
Black and Decker 5045 Type 100 Rotary Hammer Parts
www.ereplacementparts.com/black-and-decker-5045-type-100-rotary-hammer-parts-...
  1. Cached
  2. Similar
Black and Decker 5045 Type 100 Rotary Hammer Parts .... Drill Parts Hammer Drill Parts Rotary Hammer Parts. Search within model. SEARCH. Discuss ' Repair ...
Black and Decker Hammer Drill Parts & Repair Help ' Fix.com
https://www.fix.com/parts/power-tool/drill/hammer-drill/black-and-decker/
  1. Cached
Shop for Black and Decker Hammer Drill parts today. Find genuine replacement ... (Type 100). Variable Speed Reversible Rotary Hammer · 5014. (Type 100).
Black and Decker Parts - Tool Replacement Parts ' Tool Parts Direct
www.toolpartsdirect.com/brands/blackdecker.html
  1. Cached
  2. Similar
Black and Decker Drill & Driver-Drill Parts · Black and Decker Hammer Drill Parts ... Black and Decker Rotary Hammer Parts Model Schematics and Tool Parts ...
Black and Decker 5043K_TYPE_3 ROTARY HAMMER KIT Parts ' Tool ...
www.toolpartsdirect.com/blackdecker-5043k-type-3-rotary-hammer-kit.html
  1. Cached
Find the Black and Decker blackdecker_5043K_TYPE_3 ROTARY HAMMER KIT parts you need at Tool Parts Direct. Shop thousands of Black and Decker ...
Black and Decker Rotary Hammer Parts ' Tool Parts Direct
www.toolpartsdirect.com/hammer/rotary-hammer/blackdecker.html
  1. Cached
Replacement Black and Decker Rotary Hammer Parts online. Tool Parts Direct has thousands of Rotary Hammer Parts to fix Black and Decker tools. Shop by ...
www.toolpartsdirect.com/hammer/rotary-hammer.html
  1. Cached
  2. Similar
Tool Parts Direct carries the largest inventory of replacement Rotary Hammer Parts for thousands of make and models. Buy Rotary Hammer Parts online for all of ...
Black & Decker Replacement Parts - 1800ToolRepair.com
https://www.1800toolrepair.com/tool-repair-parts/black-decker
  1. Cached
Black & Decker replacement parts for all Black & Decker tools. ... Black & Decker Cordless Circular Saw Parts ... Black & Decker Electric Hammer Drill Parts.
Beyond Parts - Black & Decker ServiceNet
servicenet.blackanddecker.com/Parts/Detail/29096
  1. Cached
  2. Similar
Available, Add Parts to Cart ... Model #, Model Description, Parts Diagram. 5041K Type 1 · MACHO I ROT HAM KIT · 5042-09 Type 1 · HD ROTARY HAMMER.
black and decker rotary hammer drill Google Search
Dec 25, 2016 | Rotary Drills
What's your problem? rotary hammer will not hammer
Look for a lever that has signs hammer/drill or just drill Place the lever in the hammer position.
Feb 19, 2012 | Bosch Drills
Do all sds drills have chisel function?
The SDS designation relates more to the type of chuck on the tool for the bits than to the tool/drill itself. There are both chisels and drill bits with SDS-Plus and SDS-Max shanks, SDS-Max being the the larger of the two. As far as the tools go: Demolition hammers will only hammer and can only use pointed chisels, scaling chisels, scrapers, etc, not anything like a drill bit that requires spinning to work. Rotary hammers can hammer and rotate the bits. Rotary hammers have a selector switch with two or three positions; one for hammer only for the above demolition bits, one for rotary hammer for use with carbite tipped drill bits, and some have a position for rotation only. The rotary hammer is a more versitile tool but more expensive because of extra workings inside.
Feb 17, 2011 | Garden
Hammer drill just stopped working. Any ideas?
Usually that is a good sign of the switch going bad...
heatman101
Aug 26, 2010 | Bosch 1" Sds+ Bulldog Rotary Hammer Drill...
Makita HP1640 hammer drill dual mode - 2 hours
Exchanged Makita HP1640 hammer drill for a new one. The 2nd drill did the same thing in under an hour!! Will return for refund. Instructions say the Forward/Reverse switch must be in a full up or down position for the Hammer/Rotary switch to move; well, it is and the Hammer/Rotary switch still stops at a 1/2 way point between modes. Although I can still use the drill, instruction warnings say not to because it may potentially burn out the motor. I'll have to go with a different brand this 3rd time around. It seems to be a design flaw.
Oct 10, 2009 | Makita Drills
Stopped working in mid drill. squeeze the trigger, nothing happens
It could be a dirty switch connection in the trigger assembly , it happens to me on my electric sanders all the time , just open it up and try blowing it out with an air compressor
May 23, 2009 | Milwaukee 5318-21 1-1/2" Spline Rotary...
I have a makita hr2455x rotary hammer drill that won't hammer
you need to get that service,
the grease causes the hammering.
and probably too much pressure was applied
to it.
Mar 25, 2009 | Makita HR2455X 1" Rotary Hammer Drill
Hammer drills and rotary hammers comparison
Aug 27, 2008 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Drills Logo
46 people viewed this question
Top Rotary Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Rotary Drill Expert? Answer questions, earn points and help others
