Question about Hammer Drills
Dynalink hammer drill, hammer part stopped working
  • 2712 Answers
SOURCE: hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Posted on Aug 27, 2008
emissionwiz
  • 78257 Answers
SOURCE: Dewalt cordless drill
You have burned out the drill motor, it is shorted, the battery smoked due to a direct short, one thing I don't understand why the thermal limiter didn't trip in battery pack, I would contact manufacturer and try to get hem to buy you a new drill.
Posted on Aug 29, 2008
SOURCE: Matika hammer drill - bit stuck
The spade bit sold with the hammer drill was actually too large for the hammer drill. We found that the spade bit had over heated (not from overuse or heavy use as only two ladies were using the hammer drill) but because the bit was too large it put too much weight on the drill. The bit had to be removed from the chuck using a hammer and force causing a bearing to come out and the chuck now needs repair. Solution repair the chuck on the hammer drill and buy a lighter spade bit. Then continue jackhammering the cement out of the shower cubicle.
Posted on Mar 27, 2009
comax
  • 154 Answers
SOURCE: Bosch 11247 Hammer drill works
Usually replacing the o-rings on the piston, striker and Impact bolt will solve any hammering issues. That is considering there is no damage to the mechanical parts in the hammer mechanism.
Posted on Apr 13, 2009
  • 211 Answers
SOURCE: Bosch GBH 2-20 SE hammer drill stopped working
hi
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
Posted on Dec 16, 2009
Why has the chisel action stopped working but both hammer and drill still work?
BROKEN RING INSIDE FRONT OF THE HAMMER TUBE BY IMPACT BOLD THAT COULD BE BLOCKED BY THE BROKEN PARTS OF THE RING.
Jul 26, 2015 | Hammer Drills
Torque limiter quick to engage Why?
Usually it is a worn clutch that will cause this.
May 26, 2014 | Drills
Hammer drill just stopped working. Any ideas?
Usually that is a good sign of the switch going bad...
heatman101
Aug 26, 2010 | Bosch 1" Sds+ Bulldog Rotary Hammer Drill...
My hitachi drill is working funny
hi
try to charge the battery at full level and see what happens then.
regards savumihai71
Dec 13, 2009 | Hitachi 18V Lithium Ion Cordless Hammer...
hi
regards savumihai71
Oct 11, 2009 | Bosch Drills
Drill just stopped? not working
These tear the brushes out. You can not use them for hammering. It is a design problem.
Replace the brushes and use only for straight drilling.
Jun 28, 2009 | Bosch 1199vsr 1/2'' Dual Torque Hammer...
Stopped working in mid drill. squeeze the trigger, nothing happens
It could be a dirty switch connection in the trigger assembly , it happens to me on my electric sanders all the time , just open it up and try blowing it out with an air compressor
May 23, 2009 | Milwaukee 5318-21 1-1/2" Spline Rotary...
I have a makita hr2455x rotary hammer drill that won't hammer
you need to get that service,
the grease causes the hammering.
and probably too much pressure was applied
to it.
Mar 25, 2009 | Makita HR2455X 1" Rotary Hammer Drill
Drills Logo
49 people viewed this question
Top Hammer Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
shall39
Level 1 Expert
Are you a Hammer Drill Expert? Answer questions, earn points and help others
