How to start a TX 400? - Office Equipment & Supplies
What city is about 400 miles east of Snyder,TX on I-20?
Marshall, LA is 412 miles east of Snyder, TX
Longview, TX is 389 miles east of Snyder, TX
May 08, 2014 | Computers & Internet
How do you fix a 59.3 error
59.3 indicates the fuser motor is not starting up.
This usually means the fuser motor needs replaced.
Part Number RM1-8609-000CN
Mar 13, 2014 | HP LaserJet Pro 400 color M451dn - Printer...
I'm getting a 59.3 error on my laserjet pro 400 M451dn
have 59.3 error on my printer hp laserjet pro 300 color what to do??
Jan 10, 2013 | HP LaserJet Pro 400 color M451dn - Printer...
My Sportcraft TX-400 Treadmill shuts off after 7 seconds
Dear sIR:
This by lack of LUBE, in your schedule maintenance DECK BELT. maybe the belt is worn.
2) Lube the roller bearing.
3) Align the belt see the diagrams
4) Test the input voltage motor, if there are voltage motor, the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
Now you can RUN the software calibration for diagnose, troubleshooting. See my personal TIPS for HELPs too.
sincerely. God bless you
May 06, 2012 | Sportcraft TX 400 Walking Belt
My TX-400 stops working after 7 seconds
Lube the deck belt, this product shut down by enough friction between deck vs deck belt.
2) Lube the roller bearings
3) Adjust the deck belt see the diagram
4) TEST the input voltage motor, if there are the motor need repair.
5) Test the output voltage board, for input in the voltage motor, if there are NOT, the board is faulty.
6) Run the software calibration, for diagnose, troubleshooting.
See my personal TIPS for help too.
sincerely. God bless you.
May 06, 2012 | Exercise & Fitness
Location of speed sensor on sportcraft tx 400 treadmills
It is a simple magnet and Hall effect transistor if you have 2 small wires. It usually attaches to the 1/8 inch mini plug. You can test it with an analog meter, the resistance will be stable at rest, and with treadmill in motion, the resistance will change as the magnet passes the hall effect switch. moving the track at slow speed manually will be enough to see the needle move. Speed is calculated off of the rate of those pulses.
Jan 23, 2012 | Sportcraft Exercise & Fitness
I removed my Roger Beep from my Eagle Sidewinder 400, It still receives but will not transmit. What do I have to connect back up for it to start transmitting again? I'd be Thanking you for any help.....
If the radio is not going into TX, then you have not connected the TX line back up,
If there is no audio when you TX you have left the audio wire off.
The radio usually needs 4 wires.
TX (Puts radio into TX)
Audio (this carries the audio from the mic into the modulator)
Screen (ground cable (earth))
RX (not as common these days)
May 18, 2010 | Radio Communications
Comm. code 400
the 400 code is some cases is due to incorrect transmission levels, try turning of memory tx and send directly, or could try adsl filter on the line if needed, there are things that techs will be able to adjust if necessary
Apr 08, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
21 people viewed this question
