Question about Volfenhag Car Audio & Video
Have a volfenhag zx-7127 i know i hook all the speaker wires up correctly even bought a wiring harness for the factory to after market hook up and have no sound what so ever
jpenn1192
  • 58 Answers
SOURCE: how to wire a volfenhag dual coil sub
U HAVE TWO COILS ONE ONE EACH SIDE OF THE WOOFER, ALL U DO IS HOOK UP ONE COIL TO THE OTHER, THEM HOOK THEM UP TO THE TERMINALS IN THE BOX.
Posted on Oct 26, 2008
jmeyer847
  • 204 Answers
SOURCE: installing after market stereo
Dave,
You will need to go buy a wiring harness adapter from your local Walmart (usually cheapest there) or Local Electronics place (ie Best Buy). The wire harness that goes out from the radio goes into the Adapter and the adapter plugs into the car harnesses. Also these Adapters come with the wiring diagrams for your vehicle. They typically run 10 - 15 bucks depending on where you get them. Thanks for using FixYa!
Sincerely,
JC
Posted on Nov 21, 2008
SOURCE: no sound from speakers
did you check to make sure your vehicle didnt come with a factory amp, if it has one is it turning on? or did you remember to disconnect the negative battery cable while installing your radio, i know thats a dumb question, once i was installing a pioneer a barely crossed a couple wires and fried the radio, the radio itself worked fine and all the features etc, but it never did play sound again. i always disconnect the power now!!
Posted on Dec 28, 2008
jpk528
  • 95 Answers
SOURCE: Installing an aftermarket head unit into a 1994 Ford Bronco
are you using and after market harness to go from your bronco to the harness to the new radio. if so make sure all the colors are matched up (e.i. purple to purple, purple/black to purple/black). did the speakers work before the aftermarket unit. Also check the wiring at the oem speakers
Posted on Feb 17, 2009
  • 91 Answers
SOURCE: wiring after market stereo to factory wiring equipt with factory amp
you have to get the cable that conects your factory deck harness to the aftermarket deck, and that will allow you to use your factory speakers and amp, the wire harness is availiable at canadian tire or any stereo shop
Posted on May 06, 2009
No sound aftet market radio put in it light up but no sound
Make sure you have the correct wire harness and all speaker wires are hooked up. If so make sure your ride doesnt have a factory amp. Some bose or infinity factory sound systems have a factory amp that you may need to bypass
May 15, 2014 | Cars & Trucks
Volfenhag zx 7127
hooked up wrong switch your rc cable around
Nov 08, 2013 | Dodge Cars & Trucks
What size wire should i have for two 12 volfenhag subs
I would use 10 to 12 gauge wiring. As fare as your amp's fuse...Check to make sure you are using the correct amp fuse. Make sure your subs are wired to a ohm load your amp is stable with. Check your ground and positive connections. Check and make sure your amp's gain settings are correctly set. Your amp's gain should not be turned all the way up.
Sep 25, 2012 | Volfenhag ZX-4712 Car Subwoofer
How to wire the dual voicecoil
if you have a 2 channel amp, just wire each coil to each channel....If its a mono amp or you are bridging amp, hook up one channel like usual (+ and -) then use a jumper wire from the positive to the other positive on the speaker and do the same for the negative....
Sep 17, 2010 | Volfenhag ZX-4712 Car Subwoofer
I dont know what gos to what
Radio 12V- white/yellow
Radio Ground black
Radio Ignition yellow/red
Left Front Speaker (+/-) blue/green - gray/black
Right Front Speaker (+/-) red/green - brown/black
Left Rear Speaker (+/-) blue/yellow - gray/white
Right Rear Speaker (+/-) red/yellow - brown/white
Jun 08, 2010 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
How ot hook up speakers on this amp/
As far as I know, your sound will drastically improve if you run them +- and +-. Connect the one speaker correctly (+-) and then with the music still playing, try swapping the wires on the other speaker around and see which sounds better + to + or + to -
Hope this helps
May 20, 2010 | Volfenhag ZX-8300 Car Audio Amplifier
My name is Noah. I have a Volfenhag zx 7150 2 channel amp, and I was wondering if I could use this amp to run my mids and highs. And if yes, how would I run the wiring?
Hello violentj_1_u,
Yes, the amp can be used to power normal speakers on 2 channels.
The best way to wire the amp to a stock receiver (head unit) is to use a pair of wiring harnesses, one the standard harness that plugs into the vehicle wiring, the other a "reverse" harness that plugs into the stock receiver.
First remove the plug from the receiver and plug in the "reverse" harness. Run the speaker leads from the reverse harness to your amp inputs or to a line output converter (LOC) and RCA's to the amp. Then run the amp speaker outputs to the standard harness speaker wires. Plug the original receiver plug into the standard harness and splice the remaining wires, 12V constant, 12V accessory, ground, illumination, etc, together. Connect the 12V switched wire to your amp remote terminal.
Hope this helps.
Aug 25, 2009 | Car Audio & Video
Volfenhag ZX-7160 Car Audio Amplifier owners manual to adjust the frequency also wiring diagram diamartn64@gmail.com
its very easy to hook it up. your best bet is to join www.carstereo and ask your question there.but it is easy to set and hook up amp if you really need help email me
Mar 03, 2009 | Volfenhag ZX-7160 Car Audio Amplifier
How to wire a volfenhag dual coil sub
Oct 12, 2008 | Volfenhag ZX-4812 Car Subwoofer
Wiring
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
This should help you;rating please./
Jan 26, 2008 | Volfenhag ZX-4812 Car Subwoofer
Car Audio & Video Logo
35 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
hoyzee1
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
