Question about Garden
How to hook up rear tiller attachment - Garden
The motor runs fine, it stopped tilling, and the belts do engage properly. What happened
Randy, The gear in the gear box may have sheared a key, or damaged gear. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tiller Gearbox Trouble
Murray Ultra Tiller Tines Won Keep Spinning
Update Craftsman rear tine tiller repair stuck gears
Apr 23, 2016 | Garden
What lubricant is used to lubricate the gear box on the gc720r roybi tiller attachment
hello, i use go 80 rear end oil,works good,hope this helps.
Feb 14, 2012 | Ryobi Garden
How to attach hiller/furrower to troybilt horse tiller
how do you attach a furrower to a troy-bilt "horse" tiller
Apr 14, 2010 | Troy-Bilt Pony Garden Tiller
I need a new belt on rototiller.
To replace your tiller belt you will have to :
Take a few pictures before you get started so you know how everything goes back together.
- 1) Remove the belt guard
- 2 ) Loosen the belt pulley and remove spring, remember how this was attached.
- 3 ) Pull the belt through housing and off of the transmission pulley.
Now grab your new belt and install in reverse order.
Feb 02, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I cannot get my oil seals of my rear tine tiller It is a Troy Bilt 5.5 hp and I got the left side off but the right side tine attachment will not budge any suggestions please
Have you tried soaking the shaft area with either PB Blaster or Deep Creep penetrating oil. Try this for a few days before trying to tackle getting the tine attachment off.
Jan 26, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Choke is not hooked up to anything. What does the choke hook up to on a troy built tiller?
The choke (butterfly valve inside the carburetor) is attached to a lever on the side of the carburetor. This lever opens and closes the butterfly valve. Attach the choke cable to this lever.
Apr 29, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Broken clutch cable connector, MTD Tiller
I found micro fiche on . Click on the manufacturer's tab at the top of the page then you'll have the option to use an off-site tool to locate your machine. I used it and found my 1990 mtd rear tine tiller. I needed the cable that engages the tines - maybe the same as you. The part number for my 1990 model's cable was 746-0535. Dont know if it was still the same in 96 to 98. But look at the fiche and see.
Apr 04, 2009 | Mtd Products Yard Machines 158CC Tiller
Roto Hoe levers
If you have a model 990 rear tine then I could send photos of mine, I have two and they are bulletproof.
This may be all you need:
This shows same model in action, let me know if you want photo's.
Mar 25, 2009 | Garden
Does rear tine tiller run 2 belts
Check the Troybuilt website for specific info on your tiller.
Mar 22, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Tillers what type of motor?
* Engine Options -- Tillers come in four- and two-stroke models. o Get a four-stroke engine if you can. + Easier to start up than two-stroke models. + Require less maintenance and are more convenient because they don't require any mixing of fuel and oil. + Produce less exhaust. o The more horsepower, the more powerful your tiller will be. + Rear-tine tillers generally have more horsepower than any other kind. + You'll appreciate that horsepower when you have hard soil to till.
Aug 27, 2008 | Mantis Border Edger Attachment
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
