Question about Maxon Radio Communications
I have a hand held 40 channel maxon cb need to know where can i get a power supply and external microphone
4 Suggested Answers
  • 40 Answers
SOURCE: BATTERY CHARGER HCB-30A CB MAXON
you can get that charger aftermarket at radio shack take the walkie with you to get the right power supply the voltage should be close to where the external power plug goes into the radio.
Posted on Mar 13, 2009
kd6rhd56
  • 400 Answers
SOURCE: need a user manual for the Maxon hcb-10a hand held
www.cb-radio-shop.com/handheld-cb-radio
Hope this helps
Posted on Jul 12, 2009
  • 773 Answers
SOURCE: WHERE CAN I FIND ACCESSORIES LIKE A POWER CORD FOR
Any 13.8 volt inverter will work as long as the center is hot, and the plug fits.
Posted on Apr 06, 2010
How do you install a Maxon radio repeeter. It only has two wires that apear to be a Hot(Red) wire and a Black(ground). Should I just ground it and hook it up to a power suply?
Your correct the red wire is the positive and the black is the negative. You must also make sure to use a power supply with enough current to operate the radio. Usually a 12 volt supply that supplies about 4 to 8 amps should do the trick
Oct 29, 2011 | Maxon MCB-30 40-Channels Base CB Radio
Microphone din pin wiring for mcb30
Look at Defcom Radio mods or other sites. Snake doctors radio mods. Look up Microphone wiring for Maxon MCB-30. Just type it in to WWW.Google.com
May 01, 2011 | Maxon MCB-30 40-Channels Base CB Radio
My maxon cb radio model MCB-10A wont change channels it stays on channel 9
Hi, my name is John. Try to press or flip the button or EMG. That should do the trick.enjoy....hope this was very helpful....
Sep 01, 2010 | Maxon MCB-40 40-Channels Handheld CB Radio
HOW TO INSTALL BATTERIES IN MAXON 27KC AND WHAT ARE THE TWO BLACK THINGS IN WITH THE BATTERIES
KC27 Maxon CB need 10 batterys rechargables 1.2 v for 12v total, use the most amperes or miliamperes possible, if you have a charger case or 27-CRDL Cradle for 27-KC you can use 13.8v regulated 5 amps. máx. but need external antenna. When you put a radio in charger case it switch to use external mic, voltage, antenna & speaker. Actually 2500 mAh "AA" battery is very common and cheap. You can charge batterys on to radio case, only need a 200 mAh eliminator at 15v for 6 hours.
May 31, 2009 | Maxon HCB-10 40-Channels Handheld CB Radio
Mar 13, 2009 | Maxon HCB-30A CB Radio
Why Can i not talk to anybody but i can hear them
check your manual on wich channels are shortwave and wich are for going the distance.also what mode are you in
Nov 11, 2008 | Maxon HCB-10C CB Radio
Maxon Model MCB10A
In order to test this unit you will need a power meter with a dummy load. connect the power meter and turn on the unit, key the microphone and look at the power meter it should have a reading of < 4 watts PEP unmodulated and = 4 watts PEP modulated. If you do not have this reading the RF transmitter in the CB might be malfunctioning. You will need a RF generator, a power meter with dummy load, oscilloscope and a multimeter to troubleshoot this problem with. If you do not have or do not know what this equipment is or how it works, please take your unit to a CB repair shop. Thank you, Shuttle83
Oct 05, 2007 | Maxon MCB-40 40-Channels Handheld CB Radio
Radio Communications Logo
Top Maxon Radio Communications Experts
Steve
AnyMHz.com
AnyMHz.com
Mike Charette
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
