Question about Samsung Cell Phones
Wi fi wont connect on samsung galaxy j7 cell phone.
  • Mohammed Ebrahim M
    Mohammed Ebrahim M May 10, 2017
    Is it for all the wifi connections or just one particular connection?
Hollyecho
  • 313 Answers
SOURCE: new samsung wi-fi phone
Your router has a WEP key enabled. Each key is different as it is set by the owner of the router when it is first being setup.
That is the key your phone is asking for.
Posted on Jul 22, 2008
virtualhost
  • 2185 Answers
SOURCE: My Samsung Galaxy 3 -
To be able to find out the MAC address of your Samsung Galaxy phone, please do the steps below:
1. Press the Menu button, under the display on the left hand side.
2. A menu panel appears onscreen. Press Settings.
3. The phone's Settings menu appears. Press Wireless Controls.
4. From the Wi-Fi Controls Menu, press Wi-Fi Settings.
5. Press the Menu button (to the left under the display).
6. A menu pops up onscreen. Press Advanced.
7. The 12-character MAC address is listed in this menu.
There you go, you just have to add the MAC address where required in the appropriate place in the Wi-Fi router's configuration set up.
Please let me know if this helps you. Thank you for using FixYa.
Posted on Oct 13, 2010
  • 1010 Answers
SOURCE: i reset my samsung gt-i550 galaxy 5 android and i
If you forgot the password or don't know the security code, You have to master reset the phone. Contact your service provider to get a master reset code at free of cost....You can also visit http://www.unlock-zone.com/ and can see different options there to get unlock code for a price. Choose any price appropriate for you.
Posted on Nov 09, 2010
SOURCE: Unable to Connect to WI-FI with my Samsung Galaxy
I just had this same problem - I suspect it may have been a new app I installed that changed some settings.
I fixed mine by going into Settings>Mobile Network settings, then tick "Use packet data". Worth a try.
Posted on Dec 25, 2010
JaxPlanet
  • 922 Answers
SOURCE: galaxy samsung phone. He can't find wi-fi
He should read the manaul or call his cell phone provider's tech support.
If he still can't find wi-fi the wi-fi is turned off or hidden which can be corrected by the person who manages the wi-fi acces point.
I hope this helps him.
Posted on Jun 16, 2011
I want to Root my Samsung galaxy J7 J700F
Yes. CF root method is best option for rooting Samsung devices.
1. Turn off your phone and boot to odin mode.
2.connect to computer and locate the CF root file.
3. now you can root :)
Step by step guide here. and required Files - Galaxy J7 J700F
Apr 05, 2017 | Samsung Cell Phones
I want Stock Rom for J7 SM-J710GN
Stock smashing rims are available from the Samsung site.
Oct 30, 2016 | Samsung Cell Phones
Why will my wifi not stay turned on?
wifi not stay turned on Carol, maybe your cell is automatically switching between Wi-Fi and the mobile internet.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://recomhub.com/blog/galaxy-s6-not-staying-connected-to-wifi
About Wi Fi Assist
http://recomhub.com/blog/lg-g4-not-staying-connected-to-wifi
How To Fix Samsung Galaxy Note 3 Wi Fi Mobile Data Connectivity Issues
Mar 23, 2016 | Cell Phones
Galaxy S6 wifi issue
First, try restarting the Galaxy S6. To do that, hold the power button on the right side of the phone until prompted. Hold it down again to turn the Galaxy S6 back on. It's a simple process but it has been known to dislodge Wi-Fi issues
If that doesn't work, Galaxy S6 users will want to try rebooting the local router if that hasn't been done in awhile. We recommend unplugging the router for a good 30 seconds and then plugging it back in. Users can do the same for the modem as well. Galaxy S6 users might also consider updating the routers firmware. This process will be different depending on make and model. If those simple fixes don't work, it's time to head into the Galaxy S6's settings.
If the Galaxy S6 isn't getting a solid connection, it's time to force the device to forget the Wi-Fi network in question. To do that, head to the desired connection in Settings. On the Galaxy S6, this can be found in the Connections portion of Settings. Once there, select Wi-Fi. Tap on the desired network and select the Forgetoption. Users will then need to reconnect to the Wi-Fi network. Make sure the password is readily available or the device will be locked out.
If that doesn't work, head into Wi-Fi, tap More in the top right corner, and select Advanced. Ensure thatAlways allow scanning is turned on. You'll also want to make sure that Keep Wi-Fi on during sleep is set toAlways.
Jun 09, 2015 | Samsung Galaxy S6 SM-G920F 32GB FACTORY...
Samsung Galaxy Express Problem
make sure you have the current drivers for your router.
Nov 22, 2013 | Samsung Cell Phones
When i connect my samsung galaxy express to wi-fi my computer's wi-fi stops working
Hello Ricardo.
How are You? I Guess you need to
1- Check your wi-fi router model.
2- Check your wi-fi settings.
also please check how many devices are connected to your wi-fi at same time. because some routers can only support upto 5 device. you can check this in the settings and also routers manual.
Please let me know, once you done with it.
Regards
Galaxy samsung phone. He can't find wi-fi
Jun 16, 2011 | Samsung Galaxy S GTI9000 Smartphone
Cell Phones Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
