Question about Cameras
Hi my conlog bec23 meter cant switch on the red flash light is also off but the digital screen is on .no power .what can i do
computafixa
  • 317 Answers
SOURCE: red light flashing on power button
Sounds like the hard drive has had a failure, you need to get a replacement one, and reinstall it, along with the opperating system, and any other programs that were on the old one.
Posted on Feb 14, 2008
Kegtapper
  • 94 Answers
SOURCE: Flashing amber light, no battery recognition or power meter
Bad DC IN (probably after last repair)
One side of the DC Jack is not getting ground connection.
This happens when one of the negative leads are not connected. Simple fix for skilled tech
Posted on Feb 22, 2008
kornho
  • 781 Answers
how I solve this issue of a customer of mine.
replaced power supply and one memory stick was faulty
lesson learned: check the obvious first.. .Powersupply.. if problems persists... check your ram... if you have 2 sticks of ram,, try reseating and using one at a time or swap with known good memory.
Posted on Sep 21, 2008
SOURCE: HP 945 Digital Camera won't turn off or on, view finder is a constant red beam and the screen is on without any image. The on and off switch does nothing. New batteries do nothing. no menue or way to
it may be hung up in the middle of a shot and can"t reset if this is the case you must reset the camera to its start position
Posted on Sep 24, 2008
  • 110 Answers
SOURCE: battery light flashes red
Your battery is dead.
When the 1,3, 5 lights are flashing when you press your battery test button, then it means your battery is dead and will not hold a charge. You can still use your PC on A/C power with no issues, but if you want to use it on battery power then you will need to purchase a new battery.
sorry
Posted on Sep 16, 2009
Conlog prepaid meter does not accept token
Hi this is Alex Walker expert to help you for this issue call +1(404)981-1535 I will be glad to assist you
Jan 02, 2016 | Facebook Apps
Can't recharge my conlog meter
BEC33 User Manual - Scribd
https://www.scribd.com/doc/13748044/BEC33-User-Manual
Mar 29, 2009 - BEC33 User Manual - Free download as PDF File (.pdf), Text file (.txt) ... of this serial number is: - the meter was a Conlog meter, made in 1999 ...
Sep 08, 2015 | Cars & Trucks
Conlog bec23 prepaid meter troubleshooting
my meter shows eeeeeeee for error and cant recharge
Aug 11, 2013 | Computers & Internet
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
Why won't camera switch on and red light flashing all the time i have bought a new battery but still won;t switch on and light still flashing many thanks
hi, what type of batterys have you brought as most normal batterys you buy wont even switch the camera on you need hi power batterys such as lithium or even better go into a camera shop and they will have special high power bats, normal bats wont even switch mine on so give different batts a try
let me know how you get on or if you need fyrther assistance ok
Nov 10, 2009 | Kodak EasyShare Z730 Digital Camera
DS Not turning on - both screens flash
Try this if you haven't yet.Take the battery out,read the voltage with a meter,If low your charger is not working.Also if no meter try reinstall batery.Good Luck. DS's are unpredictable,you could not touch it for another month and it will work.
Sep 05, 2009 | Nintendo DS Lite Console
The screen is blank white and the back light keeps flashing
Sounds like your charger isn't working. Meter it. Also possible, it may nt be working IN the phone.
Aug 08, 2009 | Palm Treo 680 Smartphone
Turn off Red-Eye reduction
Hi - You can download the manual from the link underlined in blue below:
FinePix F10
See page 37 to turn off red eye:
Aug 19, 2008 | Fuji FinePix F10 Digital Camera
Cameras Logo
41 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
