Question about Dryers
Blower fan belt for Inglis gas dryer needs replacing it is approx 39 1/2" Where do I find one in Toronto Canada?
  • 249 Answers
SOURCE: Broken belt
remove top first, then front just a few screws,then put belt around the drum and pulley and reassemble,bye.eire
Posted on Dec 04, 2007
SOURCE: kenmore gas dryer,belt replacement
http://repair2000.com/wpoolbelt.htm#PHOTO
Posted on May 06, 2008
jsrock516
  • 5911 Answers
SOURCE: Need routing diagram of dryer belt on maytag dryer D7600
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to Maytag. The dryer belt diagram for Maytag should be listed as diagram E. I hope this helps you.
Posted on Jan 28, 2009
  • 10865 Answers
SOURCE: do you have a digram to show you how to change belt on inglis dry
amana.gif Diagram A
Style: Flat with ribs
Installation Tips: Ribs face toward drum
transparent1.gif frank.gif Diagram B
transparent1.gif frig.gif Diagram C
transparent1.gif ge.gif Diagram D
Installation Tips: Ribs against drum
transparent1.gif maytag.gif Diagram E
Installation Tips: Flat side of belt against drum
transparent1.gif admiral.gif Diagram F
transparent1.gif westing.gif Diagram G
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
transparent1.gif whirlpool.gif Diagram H
belt1.gif Diagram J
belt2.gif Diagram K
belt3.gif Diagram L
belt4.gif Diagram M
Posted on Jun 25, 2009
hunter19_46m
  • 7482 Answers
SOURCE: how do you change a dryer belt on an inglis dryer
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum.
I would also recommend that you remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Keep in mind how the belt is routed, this will come in handy later with you reinstall the drum and belt.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Posted on Oct 19, 2009
Inglis Gas Dryer... mercy me?
Sounds like what you said. Time for a motor. The motor has an internal overload and will shut the machine off if the motor runs hot.
Good Luck
Feb 26, 2014 | Inglis 6.5 Cu Ft Super Capacity Gas Dryer
Inglis dryer is squealing like a belt loose. it subsides during cycle but a burnt rubber smell is very prominent when finished
Replace the belt - it is old and worn out. The belt is made of rubber and is slipping, causing the smell and squeak. The belt heats up and becomes more flexible after the dryer runs a while; this is why the squealing stops.
Mar 26, 2013 | Inglis 6.5 Cu. Ft. 5-Cycle Electric Dryer...
Inglis clothes dryer heats up but drum doesn't
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
Apr 28, 2012 | Whirlpool Dryers
My dryer's vent is clear but blows no air out the back of the dryer and we just replaced the dryer belt and help with this
check the blower fan on inside of dryer. it sounds like something is wrong with it. this fan is where the dryer gets the air to blow it out threw vent pipe to outside. good-day !
Jan 28, 2012 | Dryers
My Inglis dryer is 9 years old, just started a ticking noise as it spins, what are the most common solutions for ticking noise?
Hello there and thank you for choosing fixya
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Aug 03, 2011 | Dryers
I have an Inglis Liberator gas dryer that will not sart. I push the button and it just hums. The belt is not broken but it does not turn. Any ideas?? Thanks in advance for any help.
Does the lights dim inside your house? sounds like the motor is hung up... wonder if there is anything in the blower stopping it from moving... let me know
Jun 26, 2009 | Dryers
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Clunking grinding sound
It sound like there is change or hard object in the inner dryer tumbler fins Not sure what model or make the dryer is need more info please.Maytag inglis??????
May 07, 2009 | Dryers
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Dryers Logo
23 people viewed this question
Top Dryers Experts
