Question about Water Garden
Pressure in nozzel sputters when trigger pulled
Checked all fluids; fresh and full fuel tank; clean and new filter; water hooked up and on; when trigger pulled sputters allot and not a smooth operation can;t figure it our
    Top Expert:
  • Water Master
  • 47,705 Answers
Possible
jet size is too big for the unit and the pressure regulator
or the jet is partially blocked making the pressure regulator operat intermittently
Posted on May 10, 2017
I have a 125b that has worked flawlessly for a couple of years now. It has always started on the first or second pull of the rope.
l reckon you could have water in the fuel and should drain the tank, fuel line and carby then fillup with fresh hi octane fuel. lf that don't work it's off to the mower shop....
Oct 17, 2017 | Garden
Craftsman 2200PSI pressure washer, part #580.752700 dies when trigger off.
NEVER start an engine on a power washer with pump attached. You will damage pump and get no or very little pressure. Replacing pump only fix. Pump for this washer about $49. Check spring on carb for throttle open/close
Jun 10, 2016 | Craftsman Garden
I have a 03 Honda spirit 750 --was riding yesterday when it started spiting/sputtering like it was out of fuel, I checked fuel(half tank) I put another gallon in just to be sure but no luck. Also tried...
Drain the carbs. Water condensation in the gas tank makes it's way into the carb float bowl. After a while the water builds up enough to replace gas in the carbs. Bikes don't run well on water. If that doesn't work at least no money has been spent. Next, stick in fresh spark plugs and be sure the air filter is clean.
May 16, 2011 | 2002 Honda VT 750 DC Shadow Spirit
I have an Excell model XR2600 pressure washer that will not start. I have had it stored for 3 years. I drained the gas tank and carb and put in fresh gas. Is there a fuel shutoff on this model ? It has a...
If it's been sitting for 3 years most likely the carb is gummed up. If it's getting spark, you could try a small shot of starting fluid into the carb. If it runs on this you know it's a fuel problem. Best bet would get all the MOTOR data, and buy a carb kit from you local lawn and garden equipment parts supplier. . Remove carburator and clean and install kit. Use sta-bil when you put it away next time, but even that only works about a year or so.
Jul 05, 2010 | Karcher 2500 PSI Pressure Washer
Got water in fuel tank,removed water from truckchanged fuel filter & plugs still will not start
was fuel pump changed and lines flushed---turn key on if fuel pump hums system should pressurize turn off and under hood check to see is gas is present in fuel line[have rag handy and press valve down at fuel test port which is in line between distributor and throttle body if no pressure filter clogged or pump not working -if fuel and water need to drain again -if fuel than need to test throttle body -spray some starter fluid into truck if starts or sputters than still have problem with fuel delivery --
Jan 25, 2010 | 1999 Chevrolet Silverado 1500
Pressure washer sputters and stalls when trigger is engaged
Hi k2times01
It is a always a good idea to clean out the gas tank and use new fuel, however, this sounds like an RPM problem. Try adjusting the RPM up a tad and see if it runs better when you load it. If the RPM isn't the problem, you may have to clean the carburetor thoroughly.
Jul 15, 2009 | Garden
My pump pressure is 10psi i cleaned the de filters they seem fine i have good floe out of my jets but when i hook the pool cleaner up pressure drops to almost nothing. could my impeller be the problem
The pressure you are reading is the pressure in the filter tank as water is pumped though it. When the filter is freshly charged, 9 PSI is a good pressure.
As the filter removes particles from the water the filter gets "dirty" -- it takes more pressure to push the water through it thus raising the PSI.
I think you are viewing this in reverse. Low filter pressure is "good" (as long as it stays above 8 PSI) -- as the filter cleans the water the PSI will increase -- when it gets to 15-20 PSI it needs to be back-washed and recharged.
The pressure drops when the pool cleaner is connected because pool cleaners always pull in air (in varying amounts) because of all the hose connections. This causes your filter/tank pressure to drop.
May 25, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Pressure washer stalls
Pressure washers work under very dirty conditions, no wonder they encounter engine problems. Here are a few pointers from a former pressure pump tech. The unloader is a source of engine overloading however this can easily be checked with a pressure guage attached to the gun with a tee fitting having the guage and the normal tip used for the unit. The pressure should never rise over rated pressure. The pressure should drop considrably when trigger is released. The life of the pump and engine can be increased by setting max pressure to 75% of rating. Most engine problems are from following conditions:
Leaking or misadjusted valves; clogged muffer /spark arrester; weak spark coil that is about to fail completely; kill switch/oil sensor wiring and or sensor mal function; gas cap not venting properly causing vacuum in tank and wet or dirty air filter.
All these problems easy to check, fastest repair is to disconnect oil sensor wire to check oil safety system. Then temp replace coil with known good coil. Loosen muffer bolts to check for clogged muffler. Temp run engine without gas cap to check for vacuum. Finally if everything fails, run the engine with carb cleaner spraying directly into the intake. If the engine continues to run with carb cleaner then the problem is fuel delivey and faulty carb. enjoy
Nov 15, 2008 | Honda Pressure Washer PSI 3000
Garden Logo
27 people viewed this question
Top Water Garden Experts
Vernon Taylor
roeb
Are you a Water Garden Expert? Answer questions, earn points and help others
