Question about Sony Televison & Video
Sony Bravia 55'inch led volume controls stopped working. Remote or tv button don't adjust volume
  • Sony Master
  • 10,045 Answers
Volume is controlled by the main board. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy and fix it yourself. It's easy.
Posted on May 10, 2017
I have a Sony Bravia 32-inch TV KDL-32L5000. How can I determine if a remote control is bad or the IR receiver in the TV?
Take remote and place on top of AM radio set to 600 on dial. Turn up volume and make sure you have a good battery in remote. Depress button - should hear some beeps on radio - every button you push will produce distinctive beeps. Any button that does not is a bogus area in remote. All buttons should work for remote to be totally good.
Often some heavily used buttons go bad but there are work arounds for that.
Sep 04, 2015 | Sony Televison & Video
Does my Sony kdl55w829b 55 inch HD 3D Smart tv have a built in 3D transmitter to use with the active 3D glasses ? If so how do you activate 3D viewing ?
This TV has the active 3D transmitter built in to it in some regions. It is included for the model sold in the U.K.
You need to register the Active 3D glasses before they will work with the TV. To register the glasses, turn on the TV and bring the glasses within .5m of the TV. Then press and hold the power button on the glasses for 2+ seconds (until the power button blinks alternating green and yellow). When the registration is successful, a message will show on the bottom of the TV and the green light will stay on for 3 seconds. This will need to be repeated if you use the Active 3D glasses with another TV and then use them again with this TV.
Now you need to activate the 3D feature on the TV. Press the 3D button on the remote or press the control bar on the Touchpad remote and slide the touch pad to the 3D icon and select it. Then choose your 3D option. You may also need to adjust the 3D display settings from the Home button. Press Home and select Settings. Then choose Display and then 3D.
The manual for the KDL-55W829B is available here: . The Help Guide, , has the information on using the 3D feature starting on page 56.
I hope this helps.
Dec 19, 2014 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
You would need to do a factory reset
From the Sony Forums:
factory reset to your Television.
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button.
  4. While holding the UP ARROW button, with your other hand reach around the side of the TV and press and release the POWER button on the TV set.( not the power button on the remote) it should be the top button along the side panel.
Sep 06, 2014 | Sony BRAVIA KDL46EX720 46 Inch 3D 1080p...
Sony bravia volume control not working with FIOS STB
found the problem after reading a post on this site. Last thing I used was DVD player so disconnected DVD Sony player, followed the factory reset instructions and now the volume works normally! It was the DVD player. Thank you so much for the info and lead. The problem is DVD not TV,
Jul 20, 2014
Apr 08, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
Rc65x not working with sony bravia
Direct TV rc65x code for Sony Bravia is 10000
Setup Instructions
  1. Set the "Mode Switch" to Device 1 (in the case of the rc65x set on TV).
  2. Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  3. Enter the 5 digit Code above.
  4. Try your new code and tell us how it worked!
    (It worked perfectly for our Sony Bravia using our rc65x remote)
    & Goodluck!
Jul 25, 2012 | Directv RC65X Universal Remote Control
We have a sony bravia 55 inch LED 3d tv. Problem is while watching a show such as a football game, we are not able to see the stats, etc. on the bottom of the screen or the TV identification like the NBC...
U have the tv original remote wright?Yes?U must have the tv original remote to do any adjustments to the tv for a screen sizes pictures.Look at the tv original remote carefully for any buttons on the tv remote like Aspect Ratio,Zooming - +,Picture,Picture size,Display,LCD Mode,VIEW MODE.Pushes one of these buttons a couples times to choses the correct pictures sizes for ur tv screen or what u wanted to be.
Sep 19, 2011 | Sony Televison & Video
Looking for codes for my 32 inch sony Bravia flat screen
The code for your remote is "0000" Press "TV" and then "Set" while holding "TV" wait for the LED to blink twice then release both buttons enter code "0000" the LED will blink twice again to confirm. Press "power" to test. That's the only Sony code for your remote. Hope this helps
Jan 24, 2011 | One For All URC-4880 Remote Control
Bravia KDL40W2000 Remote and manual controls no longer work
check to be sure your remote is sending IR signal, with
a smart phone camera hold remote IR eye in front of camera and click any buttons on remote, you should see
a light coming from IR eye. If no light emitting, remote needs to be replaced.
Oct 29, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Sep 07, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony 36' TV Volume Goes up on own/Stuck on Video 2
There's a setting in the menu. I think it's called "smart audio". It's supposed to adjust the volume automatically for commercials. But I don't think it works that well. Give that a try.
Jan 09, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Open Questions:
Televison & Video Logo
24 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
