Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Baking cake and F2 signal
Warmed up ok.
while baking beeping followed by F2 message and i
shut off oven to make the beeping stop
and turned back on to reheat oven.
  • GE Master
  • 3,361 Answers
F-2 on your range indicates a bad temperature sensor. Please replace your temperature sensor in the oven.
Posted on Jul 25, 2009
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
Oven shuts off while baking will not come back on until it cools off
sounds like ur oven sensor to me check with a multi meter
Sep 11, 2014 | GE Ovens
Turned oven to bake it keeps beeping with message "door"
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Apr 21, 2014 | Whirlpool Ovens
Whirlpool oven f2 error code. I turn the oven on and after the initial 10 minute warm-up i get an F2 error code and the oven beeps non-stop. I have already replaced the oven temp sensor. Could it be the...
F2
Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If this
happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN
models: check door lock operation.
3. Look for a high resistance connection
or any other cause of high resistance in the oven temperature sensor circuit.
Check sensor, sensor harness and sensor harness connection at sensor and oven
control. Replace sensor if found defective.
Remember: Oven control
(ERC) measures resistance of sensor circuit, not actual oven
temperature
Dec 16, 2010 | Whirlpool GS475LEKS Gas Kitchen Range
Control screen flashes F2 and F3; now oven element won't heat.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 10, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
F2 and F3 error messages on Tappan wall oven model 12-4980 10/03
These are the F2/F3 error codes for a Tappan oven
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
please take the time to give this solution a fix ya rating.
clarkco
Feb 09, 2009 | Tappan Ovens
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
What is F2?
F2 Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode. Ohm test the oven temperature sensor, if OK, change power relay board. F2 Oven too hot Replace relay board (if present) or oven temperature sensor
Nov 16, 2008 | Jenn-Air Ovens
F2 error, both ovens stopped working
F2 is a Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
Nov 23, 2006 | Dacor ECD230 Epicure Electric Double Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
266 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
