Question about Goodman Heating & Cooling
Why my goodman gsx 16 isn't working.
It is a newly installed unit (2 years old). We have checked the circuit breaker, changed the filters but nothing. It sounds like it tries to turn on but there is no cool air. It is a 3,700 sq ft home and we are roasting.
  • Goodman Master
  • 10,045 Answers
Ensure the compressor is running. It has a large capacitor connected to it that helps the motor to start. They go bad. There is a relay controlled by the thermostat that starts the compressor. It could be as simple as replacing the relay. Now the breaker. There are 2 of them side by side with their handles joined so when one trips so will the other. That isn't always how it works, though. Reset the breaker several times to be sure. There are fuses inside the power disconnect box on the outside of the unit. If one is blown, the compressor won't run
Posted on May 10, 2017
My air handler runs with the state in off position. I can turn it off by the breaker. Goodman GSZ130361AB only 6 years old had regular service since installed.
You are probably experiencing a stuck fan relay. The fan relay could be on a control circuit board or it could be a standard old electro-mechanical relay.
Mar 29, 2015 | Goodman Heating & Cooling
What is wrong with my Goodman AC unit?
Sounds like it has no power getting to it at all. Dont forget that some circuit breakers have UP as ON and some have DOWN as ON. Do not just assume a common way is always the same. You may even have to have one UP and the other DOWN as on. Check what the switch or circuit breaker has written on it to be sure.
AIR CONDITIONERS run like a refrigerator, they manufacture their own Heat or Cool and blow air past the unit to give hot or cold air to cool or heat the Room. These do not require flowing water.
Sometimes people (wrongly) call EVAPORATIVE COOLERS air conditioners. (An evaporative cooler just blows AIR past flowing water to humidify the flowing air and therefore "cool" the area)
An evaporative cooler therefore would require running water and without flowing water, the unit may not start due to the installation of a "fail safe" switch. An evaporative cooler would generally have a large box mounted on your roof with open sides with filters which are kept moist by the running water and through which the fresh air is sucked and pumped into your home.
There are varying thoughts on both, I personally consider the REFRIGERATED style as the most effective type, but they are more expensive to install and run.
May 29, 2014 | Goodman Manufacturing GSZ130181A - 1.5 Ton...
Code 1 on a goodman furnace. Changed filter, reset thermostat, hit the breaker for reset and still the temp is dropping and the unit is not kicking from the thermostat. Thermostat is only a year old.
You unit is under locked out mode due fail on start up. Get sand paper clean out the flame sensor, and jump the 2 wires that go to the pressure switch as soon as the inducer came on. Doing this the flame should stay on until it meet set temp at thermostat . If it does what said your pressure switch need replacement . Good luck and keep me up to date .
Feb 02, 2014 | Goodman Heating & Cooling
I have a Goodman AC unit that isn't working. I believe its the fuse. My power went out and the ac unit stopped working. the first time the repair guy said it was the fuse. I don't want to spend...
Generally, the fuses are located in a box outside by the outdoor unit. The box has a door on it and you will probably have to pull a cartridge out and the fuses will be behind the cartridge. If you don't have an ohm meter to check the fuses , just go to home depot, lowes or another hardware store where they can check them for you. Be sure to check the circuit breakers too.
Jul 11, 2011 | Goodman CKL36AR36 Air Conditioner
Hello, i have a 3 ton 10 seer goodman condensor. It is blowing the circuit breakers, sparks came from breaker box, unit is 11 years old. Can you help?
If you had sparks in your breaker box then you need to call an electrician to look into that. If the a/c is blowing the breaker you may have a shorted compressor and will have to replace it or the whole condensing unit, depends on the price of the compressor vs a new condenser.
Jun 18, 2011 | Goodman CLQ36AR49 Air Conditioner
Hello: I have a Maytag MDE9700AYM that was purchased three years ago but has been installed for less than one year. After the unit runs for 10-20 minutes, the circuit breakers trips off. Otherwise the...
It's possibly the circuit breaker rather than the dryer itself. Usually when it trips, it is overloaded or shorted. Overload can be a result of a loose connection or a bad heating element,when you remove the old breaker, see if it has some noticeable burn/corrosion marks where the wire is screwed down, I think replacing the breaker will fix the problem. Hope this helped Tim
Nov 07, 2010 | Maytag MDE9700AYM Electric Dryer
Every 1 minute it has a one second surge
Hello Dave,
The first place to start is with the line voltage supplying the condensing unit. Check ALL line voltage connections at the condensing unit, the service disconnect, and the electrical panel box. If you have a weak connection or overheating circuit breaker, it could create these surges.
Don't forget to ensure the filters and coils are clean to keep your system operating at peak performance & efficiency. :-)
May 27, 2010 | Goodman CLJ42AR49 Air Conditioner
Goodman furnace
sounds like the fan switch in the furnace is coming on and off. This is common for Goodman. or could be the heat anticipator on the t-stat. While there are several reasons this happens these are the most common.
Oct 29, 2008 | Heating & Cooling
Newly installed Goodman GPG13 gas/electric package unit installed. Cannot get AC to cycle on. Unit produces heat at all thermostst settings.
new unit and old thermostat/wire? thermostat could be bad or bad thermostat wires. try putting in new of anything old. do this wiring practice with the terminals being the letters.
r- red (24 volts)
w- white ( heat)
y- yellow (cooling)
g- green (fan)
Sep 21, 2008 | Goodman Heating & Cooling
Goodman air conditioner not running
2 summers ago, exact same problem with one of our two units outside. contractor that installed the unit when home was built was not helpful and not able to come out. another a/c company explained they would not be able to make it that day, but offered knowledge that often times in my area (San Antonio, TX) ants get into the electrical contacts of the mechanical switch and block the current.
following instructions to trip all the breakers inline and checking this it was confirmed, i cleaned the contacts with pencil erasers (a trick i learned with model car electric leads) and sure enough it's still working 2 years later.
believe it or not the same year my water well had the same symptoms and it turned out to be the mechanical switch was blocked by ants also!
Jun 04, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
