Question about The Health & Beauty
My battery are full charge I checked the reset button and the lights on the joy stick flashes. What next to check. This unit is about 6-7 mo. Old
  • The Master
  • 10,263 Answers
The number of flashes is a code for what is wrong. Go to the website of your chair and download the owners manual. It will have a chart of things to check
Posted on May 10, 2017
Jazzy select gt. batteries are good charger is new when charging the lights go from red to green and repeats, but if i hold the button one red one yellow ? i tested the batteries they are full but joy...
Still your batteries are bad. Had this problem before. If the batteries are more than 1 to 2 years old they need to be replaced. The charger only tells you it can't charge anymore, because the battery is sulfated. The meter on the chair is telling you the batteries are not strong enough to run the chair.
Jul 18, 2017 | Select Health & Beauty
Flashing 4L and check VSCsystem on dash .Batteries are 1 year old sealed units , running down within 2 days ? Could tracker units be the problem ? Toyota at service maintain it is not driving long distance...
Reset the computer, remove both battery cables, and hold them together, without touching the battery, for 30 seconds, then reconnect the battery. Drive normal the next 10 or do miles. May improve the issue.
Dec 03, 2013 | Toyota Land Cruiser Cars & Trucks
I have a metro 500 and it is about 14Yrs old i never had a problem. After i put the new batterys some thing went wrong with the cnnector cable . My batterys are fully charge but on the joy stick within 15...
loose connection on battery? if new batts then you must charge them for a full 24 - 48 hours before using. but posts must be tight. they never fully charged if connections were loose to start check all connections on chair
Oct 27, 2012 | Everest & Jennings Health & Beauty
I recently puchased an EGET MO-H04CD portable oxygen concentrator and I am having problems charging the Lithium batteries that were supplied with the unit. There are no instructions on how long you have to...
Red light normally means that the battery needs charging. The green flashing light can mean the battery is charging or has charged, and the same with the solid green light. Green in this case is good.
Charge the unit overnight and see what the indicator state is. It should not take more than 8 hours of charging for a Li-ion battery. Once you know what the full state light looks at, then you can tell what the charging indicator looks like.
In all cases, ensure you are using the proper charger with the unit.
May 14, 2011 | Health & Beauty
Chair has full charge by light lit up, but once I pus joy stick foward the light go off and just one red light flashes quickly off and on. It started when I tool gear of to put in van and once I got to my...
You could have a short. MAKE sure that all the wires are connected, these can also come loose if the machine is driven over rocks and rough terrain... Also, I would not post a phone number online, possibility for theft there.....
Sep 10, 2010 | Jet 3 Ultra Power Chair
No power to motors joy stick does not woirk
Hi. If you count how many lights were flashing and let us know then I can look up that fault code and tell you what it is. Do you have the free-wheel levers in the correct place? Check the motor and battery connectors. How old is the machine, are the motors or brakes faulty. The machine will not operate if the charger is still connected. Good luck. Neil.
May 24, 2010 | Jet 3 Ultra Power Chair
My sony reader is frozen. I cvharged it
The Reader may not turn on, or it may appear to be frozen if the unit needs to be reset, the battery is completely discharged or moisture condensation has occurred.
Please perform the below mentioned steps and check whether it helps.
Because each of these steps represents a possible solution to this issue, check the Reader status after completing each step.
1. Connect the Reader to a USB connection or optional AC adapter. Allow approximately 5 min for it to turn on. If it does not turn on automatically, try to turn it on again. If it still does not turn on, continue with the rest of this procedure.
2. Perform a soft reset. Just press the RESET button using a sharp-pointed object
3. After the RESET button has been pressed, slide the POWER switch to activate the Reader again. If the Indicator light next to the power button on the Reader is yellow , the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
4. If startup did not complete, connect the Reader to the computer or optional AC adapter and perform a soft reset again.
5. Disconnect the Reader from the computer (if applicable) and then slide the POWER switch to activate the Reader. Check if the Indicator light next to the power switch on the Reader is yellow (indicating it is turning on) and if the unit is responding.
6. If the unit is not responding but Starting up... is displayed on the screen, attempt a hard reset.
7. If the unit is still frozen, connect it again to the computer or optional AC adapter and while connected, check if the Indicator light next to the power switch on the reader is red . If this light is red , allow the Reader to charge for one hour so there is sufficient charge for troubleshooting.
* If your computer goes into hibernation or sleep mode, charging will stop and the red charge indicator on the Reader will turn off.
* It is recommended to charge the Reader while you are using the computer or to adjust your sleep/hibernation settings of your computer to avoid any interruption in the charging process. You also can use the optional AC Adapter model ACS-5220E.
8. Once the Reader has sufficient charge, perform these troubleshooting steps again.
9. Under certain circumstances, moisture condensation can occur. Moisture condensation can be caused by moving the Reader between temperature extremes or if the Reader has come in direct contact with moisture. If you suspect moisture as the cause, allow the Reader to sit for a few hours before attempting to turn it back on.
General notes regarding the battery status:
* You can verify the charge status by disconnecting the Reader from the computer and checking the battery indicator. The battery indicator will display 4 black bars when it is fully charged.
* It will take approximately 4 hours to achieve a full charge with a computer. It will take approximately 2 hours to achieve a full charge with the optional AC Adapter.
If the issue still persists, service of the Reader is required. Please follow the below link to get it repaired:
http://eservice.sony.com
Jan 20, 2010 | Sony E-reader Portable E-book MP3 Player
The USB connected screen is frozen on my reader and I don't know how to fix it.
The Reader may not turn on, or it may appear to be frozen if the unit needs to be reset, the battery is completely discharged or moisture condensation has occurred. Please perform the below mentioned steps and check whether it helps. Because each of these steps represents a possible solution to this issue, check the Reader status after completing each step.
1. Connect the Reader to a USB connection or optional AC adapter. Allow approximately 5 min for it to turn on. If it does not turn on automatically, try to turn it on again. If it still does not turn on, continue with the rest of this procedure. 2. Perform a soft reset. Just press the RESET button using a sharp-pointed object 3. After the RESET button has been pressed, slide the POWER switch to activate the Reader again. If the Indicator light next to the power button on the Reader is yellow , the unit is attempting to start up. If this is the case, allow it a few moments to complete startup. 4. If startup did not complete, connect the Reader to the computer or optional AC adapter and perform a soft reset again. 5. Disconnect the Reader from the computer (if applicable) and then slide the POWER switch to activate the Reader. Check if the Indicator light next to the power switch on the Reader is yellow (indicating it is turning on) and if the unit is responding. 6. If the unit is not responding but Starting up... is displayed on the screen, attempt a hard reset. 7. If the unit is still frozen, connect it again to the computer or optional AC adapter and while connected, check if the Indicator light next to the power switch on the reader is red . If this light is red , allow the Reader to charge for one hour so there is sufficient charge for troubleshooting.
* If your computer goes into hibernation or sleep mode, charging will stop and the red charge indicator on the Reader will turn off. * It is recommended to charge the Reader while you are using the computer or to adjust your sleep/hibernation settings of your computer to avoid any interruption in the charging process. You also can use the optional AC Adapter model ACS-5220E. 8. Once the Reader has sufficient charge, perform these troubleshooting steps again. 9. Under certain circumstances, moisture condensation can occur. Moisture condensation can be caused by moving the Reader between temperature extremes or if the Reader has come in direct contact with moisture. If you suspect moisture as the cause, allow the Reader to sit for a few hours before attempting to turn it back on.
General notes regarding the battery status: * You can verify the charge status by disconnecting the Reader from the computer and checking the battery indicator. The battery indicator will display 4 black bars when it is fully charged. * It will take approximately 4 hours to achieve a full charge with a computer. It will take approximately 2 hours to achieve a full charge with the optional AC Adapter.
If the issue still persists, service of the Reader is required. Please follow the below link to get it repaired: http://eservice.sony.com
Jan 02, 2010 | Sony Reader Touch PRS-600
My reader's menu is frozen and it wont respond to any buttons. How do I fix it?
Nov 17, 2009 | Sony E-reader Portable E-book MP3 Player
Wont charge
did you try plugging in 560 driectly to charger then run it?
Dec 26, 2008 | iRobot Roomba 560 Robotic Vacuum
Health & Beauty Logo
27 people viewed this question
Top The Health & Beauty Experts
Terry Kitt
Terry Kitt
Level 1 Expert
Elliot Kelly
Elliot Kelly
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
