Question about Asko Dishwashers
My asko dishwasher has a faulty on /off switch I think. Hold down switch and it stays on release and it goes to off model No D3351 with switch at top of door. Can you please help .
  • 1462 Answers
SOURCE: Dishwasher confused
i suspect this is nothing to do with switching off during the cycle.
take the bottom plate off and check if there is water leaked into the bottom pan. alternatively, if you can, tilt the machine back to 45deg and see if water runs out.
most machines have a float switch in the base so that if water leaks, all that will happen is that the drain pump runs and i think this is what you are hearing
Posted on Aug 07, 2008
SOURCE: Faulty Asko dishwasher
We were told by an ASKO technician that it has something to do with a balance issue. You could try tilting the machine forward (make sure you've removed side screws into walls first though otherwise you could damage the cupboards).
Posted on Apr 11, 2009
SOURCE: Lights on the Asko D1996 keep blinking
This depends on the blinking pattern. Of the eight lights on the panel, if the four on the left blink on and then the right four lights blink on as the left ones go off, and keep blinking back and forth, that just means the mode has been set and the Start button pressed. After closing the door it should just continue on wherever it is in the cycle. (This is normal operation).
If you hold down the Start button, this resets the dishwasher. If you then close the door, nothing will happen because it thinks it's done.
If the lights are blinking in a different pattern, such as they all blink on and off in unison, that indicates an error condition and needs to be diagnosed. If the pump is not running constantly, then at least it's not because water is leaking out somewhere.
Posted on Sep 18, 2009
  • 351 Answers
SOURCE: f7 code
yes remove filter and water from under filter theres a small chamber at the back of the sump,it may be full of fat clean it with your finger then try running some heavy wash cycles to clean it.
Posted on Jun 17, 2010
SOURCE: dishwasher detergent door won't release soap
There's an answer at: http://www.partselect.com/dishwasher+cup-wont-open+repair.htm.
Pretty in depth, but not a simple fix.
Posted on Aug 06, 2010
Asko d3251 randomly stopping during cycle.
The thing that immediately comes to mind is a faulty door switch or latch. The door switch can be replaced and you might be ok. But the latch would be more tricky to check. Sometimes if dishwasher is not level or if the door springs are misalinged the door tends to slip and release the latch due to pressure. It works when you open and shut. But not sure about the night time cycle. That sounds a bit creepy if it starts again by itself. Why not put a tape around the door and then start. That will help eliminate the obvious ones. The other thing that exends dishwasher cycle time is the lack of adequate water temperature. Could be heater or thermostat or both.
You should be able to stroll through the parts by selecting categories on this site.
http://www.repairclinic.com/Shop-For-Parts/a9b126d867701/Model-D3251White-Asko-Dishwasher-Parts
May 01, 2014 | Asko 24 in. D3250 Built-in Dishwasher
Front top panel broken on ASKO model 1375 where can i get a replacement
Parts of that type might be hard to get for this model.
Try this site and select the part based on your dishwasher finish.
http://www.repairclinic.com/Shop-For-Parts/a9b126d610738/Model-1375-Asko-Dishwasher-Parts
Apr 01, 2014 | Asko 1375 Dishwasher
Asko dw 95.2 model 1705 after 6 years of use the dishwasher top drawer rolls out. Will not stay inside when main door is open.
Check the level and tightness of the slide rails--they may have come loose after the years of use. Make sure the dishwasher case itself is level. Hope this helps!
Jun 29, 2010 | Asko 24 in. D3250 Built-in Dishwasher
F7 code
May 02, 2010 | Asko 24 in. D3350 Dishwasher
Asko dishwasher starts and immediatly stops
Hi mike, thanks for the clarification. Having this info, I am not sure this model is as the post indicates - "1595". Is it possibly a 1473 or 1474 model with a power button by the door handle ? If so, that is the most common problem with that style Asko. The contacts inside the button make momentary contact & then stop which requires replacing tge switch. Let me know if it is indeed one of these models or confirm what model number it is ok ? Thanks, Macmarkus
Apr 22, 2010 | Asko 1595 Dishwasher
Asko dryer model#7005 when i start the dryer i push the start button and let it go it does not stay on. If i hold the start button down the dryer will stay running.
Hi There, Sounds like there is a relay switch that may be faulty, the power should latch on when you press the start button, I am unsure of this model type, but usually there is a small PCB inside the unit behind the facia, remove the top to expose it, and you can either replace the PCB or replace the relay the latter being cheaper but more work as you will have to reflow and solder the relay
Nov 27, 2009 | Asko Dryers
Asko 1876 dishwasher soap flap opens as soon as power on.
I don't know about the control panel - I am having trouble with mine too, but in regard to the soap dispenser -- don't use it anymore. Just buy those little tablets. That is what the secretary at the repair shop told me when I had a problem and that's been fine.
Sep 24, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Drainage Problems
Turn off the dishwasher by pressing the on/off switch on the top left of the dishwasher. Wait 5 seconds. Press and hold the program button on the right side of the front of the dishwasher. As you are holding the program button, press the on/off switch again. Release both. This should reset the machine
Apr 13, 2008 | Asko 24 in. D3120 Dishwasher
Dishwashers Logo
85 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
