Question about Panasonic Televison & Video
How do I fix the Panasonic HD 3D Plasma TV Model TC-P50ST30 with 14 Flashes?
  • 205 Answers
SOURCE: How can I get tv audio thru my surround reciever
check to make sure you connected the RCA jacks to the audio output on the tv then go to the set up menu on the tv and select external speakers
Posted on Oct 15, 2009
  • 458 Answers
SOURCE: Thin red vertical line on plasma tv screen, can be
vertical line on screen 80% up pdp panel problem
if you need replaced you can try call bestbuy in home service....
Posted on Dec 04, 2009
  • 115 Answers
SOURCE: Panasonic tc-p42x1 has no power and led flashes 10
No, it is definitely not worth repairing. The panel is shot and you can buy a new lcd tv for less than the repair.
Posted on Aug 10, 2010
SOURCE: i have a panasonic 50 inch tc-50px24 plasma tv. i
blinkin de red led tv panasonic plasma
Posted on Feb 13, 2011
  • 3267 Answers
SOURCE: I have a Panasonic Model TC-P50S1 plasma TV and
Panasonic utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to a major failure.
Panasonic uses the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light indicates an area of concern and helps the technician to isolate the problem and order the correct parts. This in turn speeds up the repair process, keeps parts cost down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in most cases.
So contact an authorized service center.
Posted on May 28, 2011
My panasonic plasma started showing vertical lines
Look at the buffer board or the Y sustain board on a plasma having picture aberrations.
Sep 16, 2016 | Panasonic Viera 50" Class 1080p Full HD 3D...
How to fix vertical lines on a panasonic viera 3D lcd 55" tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 01, 2016 | Panasonic 55" L55ET5 Viera 3D Full HD...
Panasonic viera plasma tv 10 blink code
1. Hold the front panel power button for over 15~20 sec and try.
2. See the youtube video
Mar 09, 2016 | Panasonic Viera Tc-p50gt25 50" Inch Full...
My panasonic plasma tv model#TC-P65S1 will not power up the led light blinks 8 times and failed to boot up
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience
Aug 01, 2014 | Panasonic VIERA TC-P60GT50 60-Inch 1080p...
My Panasonic TCP42GT25 turned off by itself and won't turn back on. The power source light is blinking 4 times and then pauses. any ideas on how to fix this? thanks.
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 23, 2013 | Panasonic 42" Class Viera TC-P42GT25...
Stuck on 480i with Panasonic HD Plasma
It sounds that a software update is necessary. Contact the service centre for Panasonic, to get the latest software to this model Plasma tv.
Jul 04, 2013 | Panasonic VIERA TC-P55ST50 55 in. 3D...
My panasonic tc-p58vt25 58 3d 1080p wont turn on
count the number of blinks. this will indicate the problem area.
Feb 22, 2013 | Panasonic TCP58VT25 58 inch VT25 1080p...
Optical port problems
a suggestion, take it back and tell them when you opened the box it was this way--a whole pc board is likely to have to be replaced that has the connection on it.
Dec 23, 2012 | Panasonic VIERA TC-P50ST50 50-Inch 1080p...
Televison & Video Logo
27 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
