Question about Electric Tools & Hardware - Others
Having problems finding a drive belt for an old electric Am-Tech planer that has 82mm cut or thereabouts. Can anyone help.
Are planer belts standard sizes.
    Master:
  • 923 Answers
Did you try Sears?
Posted on May 10, 2017
I have a Arlec 650 enforcer wood planer. Is there any chance of finding a drive belt or size. Ceased making 10 years ago Thank You
manufacturers seldom make drive belts for their products as the cost is too great so they use generic belts with their name on them. take the old belt to repairers ( appliance repairers) and see if there is belt similar that will fit.(Dewalt, hitichi, ryobi, ozito etc)
Feb 05, 2015 | Crafts & Hobbies
Replace the drive belt
Do you mean replacing the cutter head drive belt?
With power off start the ribbed belt on the motor pulley, insert allen wrench into cutter head shaft. slowly rotate cutter head while feeding belt onto cutter head pulley. While rotating head, alternate between pulleys feeding it on one rib at a time. Softening the belt in hot water is NOT necessary to install the belt in this fashion.
Complements of
http://www.ereplacementparts.com/delta-22560-type-planer-parts-c-3275_3571_3579.html
Cheers
Billy of Hayward Delta 22 560 Type 1 Planer Parts
Sep 16, 2014 | Delta 12" Portable Planer Model 22-560 W/...
Makita planer 2012NB belt replacement
Use dish washing liquid to lubricate the roller and belt on both rollers and place the belt equally on each roller and move in on both rollers evenly
Feb 15, 2013 | Makita 2012NB Electric Planers
Planer problems
If you're looking at the planer from the infeed side, there's a belt guard on the right side of the head. Remove it and check the condition of the drive belt. If it's broke the motor will spin without powering the cutterhead and feed rollers. The drive belt is still available as part number 22-563 on sites like http://servicenet.dewalt.com/ and www.ereplacementparts.com. Just put your model number in their search box and find the drive belt in the breakdown.
Aug 01, 2012 | Masonry Tools
When I feed the board in it stops then starts again. ever four inches. Leave a little snip in board. I've replaced the belt an the chains on the in feed and out feed still have this problem.
Couple of things to check:
1. Are your knives sharp? Dull knives will cut not fast enough to keep up with the rollers.
2. What is the depth of cut? Dewalt's planers cannot plane a board to excessive depths.
3. Are you rollers clean? Dirt, pitch or possibly grease could affect your feed rate.
4. The belt/chain for your rollers engaged or are they slipping? Open up the planer and check for wear or possibly broken belt/chain.
Snipe is usally caused by improper support while exiting the planer. Use outfeed rollers set to the correct height. Also chek that you outfeed bed is aligned with the bed of the planer.
Hope that helps,
Dec 20, 2010 | Dewalt Tools & Hardware - Others
Where do i find a belt for ryobi 18v planer model cpl 180
If you have the remnants of the old belt, take it to a well stocked hardware or auto parts store. If the belt is missing, you will need to measure the width of the outer 'V' on either pulley, the diameters of both pulleys, and the distance from shaft center to shaft center. The folks at the store can compute the proper belt width and length from that. Be sure to set the motor position so that there is about 3/8 to 1/2 inch deflection of the belt at mid-point and that the two pulleys are in the same vertical plane. This will greatly increase the belt life. Hope this helps!
Sep 12, 2010 | Ryobi Thickness Planer Blades
Drive belt for planer epn 7582 n to replace a broken one
if you need a part check tool parts direct. if you have the belt, pull the side off opposite the handle that raises and lowers it. you have to roll the old belt off and then you have to roll the new one on. it will be tight and hard to do. if it isn't, there is something loose and that is not good.
Aug 31, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
I have a MTD yard machine, 42 inch ride on mower. 18.5 hp v twin briggs and stratton motor.7 speeds. The model details under the seat are missing so difficult to identify. I brought it secondhand and was...
find your local mtd distributor, the fact that it is an 18.5 v twin briggs and the 42 inch cutting width will tell them what model you have, then you can go to mtdproducts.com and order a manual, or get it from the distributor, serial number or model number will get you a manual or parts book
Oct 28, 2009 | Mtd Garden
Belt for Powermatic 15" Planer (Planer Model M-0460213)
Order the first one through Powermatic, then order any new replacements from the number on the belt. Or you can measure the pulley belt width and use a metal tape measure to find the total length by running the tape (number side in) over each pulley rim. Then order as a standard hardware source belt. Make sure the motor is bolted down about midway in it's mounting slots when measuring.
Sep 07, 2009 | Powermatic 1791210 Model 15S Deluxe Planer
Tools & Hardware - Others Logo
Top Electric Tools & Hardware - Others Experts
eddie_brown
Level 1 Expert
Mike Carew
Jim London
Jim London
Are you an Electric Tool and Hardware - Other Expert? Answer questions, earn points and help others
