Question about KitchenAid Microwave Ovens
Dimensions of Kitchenaid KHMS145kss-1 - KitchenAid Microwave Ovens
Min distance from gas cooktop
First, read the service manual. Contact the seller, or read the FAQs on the KitchenAid website.
Jun 25, 2014 | KitchenAid KHMS145KSS Microwave Oven
Fan wont turn off
Is it the vent blower or the magnetron cooling motor. if it is the blower then it could be a bad thermal switch that is designed to come on if the bottom surface gets too hot. or a bad relay on the control board. last it could be a bad touch pad. the magnetron cooling fan could be a bad door interlock switch or relay on the control board.
Microwave makes loud sound when running.
You don't. If it's doing that, there's something wrong with it. It needs to be replaced.
Apr 29, 2014 | KitchenAid KHMS145KSS Microwave Oven
Samsung microwave internal vent cover melted
The temperature reached a high enough value to make the plastic melt .The device ran for too long. The device ran without any substance (food) to heat.
Nov 26, 2013 | KitchenAid KHMS145KSS Microwave Oven
Safe to Use with Loud Rattling Sound?
It's not a good idea to continue to use it when it's making an unusual noise.
It may be arcing, which can lead to further failure or a fire, or it may be a defective stirrer or fan ,which can lead to uneven cooking or further failure.
$360 for a service call? Are you in Alaska or on Mars? That's insane. Maybe you can contact another servicer in your area?
Jun 09, 2013 | KitchenAid KHMS145KSS Microwave Oven
Khms155lss-3
You need to order the part from KichenAid, or visit a appliance dealer/repairman.
Mar 18, 2012 | KitchenAid KHMS145KSS Microwave Oven
The microwave runs like normal but doesn't actually heat anything. I went to heat something and it came out cold. Timer set just fine, it ran and sounded like it always does, turntable turned, it dinged at...
The most likely problem is the magnetron that heats the food, the other less likely is the high voltage transformer that energizes the magnetron. To replace either part with labor would be as much if not more than a brand new microwave oven.
Jan 19, 2011 | KitchenAid KHMS145KSS Microwave Oven
Looking to replace the plastic piece on the vertical edge of the door (handle side) on my Kitchenaid Microwave/Hood combo khms145kss1. Is it possible to just replace this instead of purchasing the entire...
They don't show the entire door assembly as being available.
But you can replace the outer door frame (outer door panel)part number 8184319.
At $167.94, it's not cheap. But you can get it here.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 29, 2009 | KitchenAid KHMS145KSS Microwave Oven
Kitchenaide Microwave KHMS145KSS rattling noise
there is a possibility that sme of the wireing or the fan has become loose best checking it .
Jan 01, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Loud humming noise
If all of your door switches check out, replace the magnatron, capacitor, and diodes.
Oct 27, 2008 | KitchenAid KHMS145KSS Microwave Oven
Microwave Ovens Logo
75 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
