Question about Garden
SOURCE: Problem mowing my lawn.
I had the same problem and I already found those recommended solutions\ causes on the web:
1. The
motor isn't on full throttle.
2. The blade is upside down.
3. The grass is
too high when cutting it.
4. Overlap your cuts.
It helped my problem/ I hope it will help yours too!
Posted on Sep 01, 2008
SOURCE: Deck belt adjustment
Unless you adjusted the old belt when it started to stretch you either have 1. too long of belt or 2. (most likely) routed the wrong way in relation to the idler or "mow" lever pulley.
Please rate this solution!
Posted on Mar 18, 2009
SOURCE: mows crooked
Riding mower decks are typically canted (offset) to avoid this issue. Double check to verify the new blades are the same length as the original blades.
Not all mower blades are created equally, universal replacement blades do not adhere to the same standards as OEM blades for size, hardness or many additional standards built into the OEM blades when the mower deck was designed.
Posted on May 26, 2009
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
SOURCE: Strange noise from deck of Toro LX426
The engine wont have an impact with the deck because its belt driven. It sure sounds like you have a bad set of spindle bearings,just turning it by hand you wont hear any noise it has to be going fast to hear it. The noise may be coming from your clutch instead of the deck,and it sounds like the deck. Have these things checked out.
Posted on Aug 09, 2009
Jul 05, 2016 | Garden
Aug 03, 2015 | Garden
Sep 15, 2014 | Garden
Jun 06, 2013 | Garden
Aug 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Jun 12, 2011 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Aug 09, 2009 | Garden
Jul 14, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Jun 09, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mar 17, 2009 | Mtd Garden
Apr 23, 2018 | Toro Garden
37 people viewed this question
