I have a idylis model#0625615 portable a/c. It comes on runs about 10 minutes and shuts off with error code E1.
Master_Tech
  • 770 Answers
SOURCE: Whirlpool Duet dryer error code
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
Posted on Aug 05, 2008
jyackle5
  • 8197 Answers
SOURCE: I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
Posted on Dec 18, 2008
  • 423 Answers
SOURCE: What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Posted on Mar 30, 2009
SOURCE: tredmill error code e1
Trimline treadmill starts up then code E2 comes up, and the display shuts down.
Any ideas???
Posted on Dec 20, 2009
6ylucy
  • 742 Answers
SOURCE: boston innovative products MOB 10KDCHR portable
i found the user manual for it at:
manualfox.com/link/bostoninnovative.htm
Posted on Feb 13, 2010
Need Remote for IDYLIS portable air conditioner
Fixya does not sell remote controls.
Oct 03, 2017 | Optics
E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Jun 05, 2008 | Haier hwr10xc6 Air Conditioner
Duet. What does F8E1 code indicate needs to be done to restore operation?
Check out the Link and the info below.
Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
If a "flood saver" device is being considered:
  • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
  • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
Jan 19, 2016 | Whirlpool Washing Machines
I have an E1 error message on my Idylis 400 square foot air conditioner. There is no water in the system.
Add the water in the system and see what happens, Even a horse needs water to work. I take it your unit is an evaporative A/C. I have a Penguin water assisted A/C, of which I have to fill a large plastic container then load it in the unit and start the A/C. It cools well but doesn't really cool like a wall A/C. But it's better than nothing.
Jun 16, 2014 | Idylis 434 Sq. Ft. 280 CADR Air Purifier...
Air condit. runs for ten minutes , shuts off and displays E1
You should first look in the instruction/operation manual usually in the back pages for trouble shooting or code faults (errors). There should be a list of faults such as E1, E2, E33, E44 etc. and an explanation of each code. If you cannot find this info, call the manufacture ; they will tell you exactly what the E1 fault code stands for and possibly what will correct it. Ask for technical support. The fact that it runs for 10 minutes and stops; if you unplug it or turn the control to off, will it start again when you reenergize it ? This could indicate low voltage from the electric source. Are you running it with an extention cord or is the electric circuit line a very long run and robbing power before it gets to the unit? Have you checked the filter so that it is clean enough for good air flow, otherwise the unit will detect the low air movement from a dirty filter and shut itself down.
Aug 10, 2010 | Sharp AF-S100FX Comfort Touch Air...
Dec 18, 2008 | Kenmore Elite HE4 Electric Dryer
LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
Whirlpool Duet dryer error code E1 keeps coming on after a few minutes of running shuts down dryer.
E1=Thermistor open
Aug 05, 2008 | Dryers
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
