Question about In Office Equipment & Supplies
No label for FINAL STEP in envelope received. How doI get label?
How to print envelop on HP 3390
you would be better using sticker sheets.
see for an example
http://www.officeworks.com.au/shop/officeworks/c/office-supplies/labels/address-labels
your local office supply shop would have something similar
Some labels have downloadable templates to make it easy to line up the addresses to the laser label sheets
Trying to print on the envelope could cause jams inside the printer
Aug 13, 2016 | HP LaserJet 3390 Printer
I'm having trouble addressing an large envelope the printer wants to print from the upper photograph tray and not accept the envelope from the lower tray. I have the MX922 printer.
The upper tray on my 6120 has adjustable guides on either side of the document and can be set from 2" to 8.75" wide. It is not intended just for photos! I use it for ALL envelopes that will fit. I use the MS WORD "Mailings", "Envelopes", "Options", "Envelope Size" menu to tell the printer what size the envelope will be (any size not listed in the standard list can be customized from the CUSTOM option at the bottom of the envelope list). Your word processor should have something similar. Running from the tray should be a straighter run and will actually place less distortion stress on the envelope.
Use a mailing label for anything larger than 8.75". You can download a program from Avery (and probably other label manufacturers) that really makes labels simple to produce. Labels should also be run from the rear tray if possible so they won't wrap around your rollers.
Happy Printing.
Feb 10, 2015 | Canon Pixma MX922
When I try to print on a 6x6 envelope on my hp envy 110 printer it tells me it is the wrong size paper. No where is there a setting for a 6x6
Print labels and envelopes
With the HP ENVY 110 series, you can print on a single envelope, a group of envelopes, or label sheets
designed for inkjet printers.
To print a group of addresses on labels or envelopes
1. Print a test page on plain paper first.
2. Place the test page on top of the label sheet or envelope, and hold both up to the light. Check the spacing for
each block of text. Make adjustments as needed.
3. Load the labels or envelopes into the paper tray.
CAUTION: Do not use envelopes with clasps or windows. They can get stuck in the rollers and cause
paper jams.
4. Slide paper-width guides inward against the stack of labels or envelopes until the guides stop.
5. Select the appropriate options.
• On -Paper/Quality- tab select a Plain paper type.
• Click the [Advanced] button, and select the appropriate envelope size from the Paper Size drop down
menu.
6. Click [OK], and then click [Print] or [OK] in the Print dialog box.
If you print from within a program that DOES have that listed (like M$ Word,) then you don't need the limited printer driver to specify the paper size.
Tallon41
Sep 08, 2012 | HP ENVY 110 Wireless e-All-in-One Inkjet...
How do i print envelopes on the HP 1350?
  • Remove all paper from the paper tray.
  • Slide an envelope into the tray, with the envelope flap up and to the left (print side down), until it stops.
  • Adjust the paper-width guide against the envelope.
  • Be careful not to bend the envelope.
  1. In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
  2. In the Envelopes and Labels dialog box, click the Envelopes tab.
  3. Click Options .
  4. From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
  5. Click OK , and then click Close to close the Envelopes and Labels dialog box.
  6. Click File , and then click Print to print the envelope.
Dec 01, 2010 | HP PSC 1350 All-In-One Thermal Printer
Please teach me how to use my HPF4185 to print envelopes. Thanks.
Hi
Use the product software, also known as the printer driver, to change the print settings for your envelope size and type. Then, use the Envelopes and Labels tool in Microsoft Word to select your envelope size.
Step one: Adjust the print settings
-In Microsoft Word, click File , and then click Print .
-Make sure that your product is in the Name drop-down list box, and then click Properties .
-Click the Features tab, or the Paper/Quality tab.
-Select an envelope size from the Size drop-down list.
-If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
-Select Custom from the drop-down list.
-In the Custom Paper Size dialog box, type a name for the new custom size.
-In the Width and Height boxes, type the dimensions.
-Select the unit of measurement, and then click Save .
-Click OK to close the Custom Paper Size dialog box, and then click OK again to close the Properties dialog box.
NOTE: You must exit the Properties dialog box to apply your changes.
Open the Properties dialog box again, and select the new custom size from the Size drop-down list.
-Select the paper type.
-In the Paper Type or Type is drop down list, click More .
-Click the desired paper type, and then click OK .
-Select the paper source from the Paper Source drop-down list.
-Change any other settings, and then click OK to close the Properties dialog box.
Step two: Set the correct envelope size
-Set the correct envelope size in the Envelopes and Labels dialog box before printing envelopes.
-In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
-In the Envelopes and Labels dialog box, click the Envelopes tab.
-Click Options .
-From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
-Click OK , and then click Close to close the Envelopes and Labels dialog box.
-Click File , and then click Print to print the envelope.
NOTE: When you finish printing the envelopes, return the paper size and the paper type settings to the defaults.
Regards
Riztech
Oct 30, 2010 | HP Deskjet F4140 All-In-One InkJet Printer
Hp laserjet4 printer will not print labels or envelopes
MP LOAD,
PC LOAD, or
LC LOAD
paper size,or
envelope size
The printer received a request for a paper or
envelope size not available in the printer.
MP LOAD: Load MP Tray with the requested
media. If the size is not selected in the printer
control panel, use the [MP[Paper[Size] key to enter
the requested size, or press [Shift] + [Continue] to
draw the requested size from another source, if
available.
Note: If MP LOAD remains in the display, you may
have to clear the buffer by resetting the printer.
Press [Shift] + [Reset].
Feb 12, 2009 | HP LaserJet 4 plus Printer
Printing envelopes and labels
I foubd the Brother website to be very helpful with my label and envelope printing:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000063/faq000063_007.html?reg=us&c=us&lang=en&prod=hl5240_all&Cat=4
Apr 01, 2008 | Brother HL-5240 Laser Printer
Making address labels and envelopes
Vista is the operating system. I am not using Vista, but I can pretty much promise you there's nothing built in to create labels and envelopes.
Go to www.avery.com and take a look at their free software to create address labels using their products. I'm not sure if you can print directly on envelopes with their software, but if you have Microsoft Word on your computer it will do that for you.
Good luck.
Nov 27, 2007 | Acer Aspire 5100 Notebook
Envelopes and labeles
Go the "print" dialog and select "settings". Ensure that the paper size, margins and orientation are not set for 8.5x11.  You did not mention the software you are using to print the envelopes/labels so this is the only guess I can give.   I have seen software that made me have to override the settings before.
Oct 15, 2007 | Samsung ML1740 Laser Printer
Top In Office Equipment & Supplies Experts
Mohul
Mohul
Level 1 Expert
Tygh Duval
Tygh Duval
Jason
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
