Question about Olympus Televison & Video
My olympus V-8100 PC (digital voice recorder) is dead, won't turn on at all
Changed batteries multiple times in last week. Turns on, but then the buttons won't respond. Like won't record, won't play, etc. Then after a couple of times of pushing those buttons, it dies again, like you need to change the batteries. This most recent time, it doesn't even register at all, doesn't start up at all. Just blank and dead. I had a couple of recordings in there that I needed ...
SOURCE: Error message on Olympus
Hello evrybody,
I had the same problem but i fix it.
This is the solution :
1- When the "ERR" message is shown, press Disp/Menu Buton for Two seconds and at the same time "Stop" Buton.
2- The "FOR" Message is shown
3- wait for some minutes
That's all
PS : All the recrded messages will be deleted
Posted on Mar 17, 2008
SOURCE: RP5022A Handheld RCA Digital voice recorder
there is a link to a complete user's/instruction manual (PDF file) under "Product Details" here:
http://www.amazon.com/RCA-RP5010-Digital-Voice-Recorder/dp/B00006LEJ9
Posted on Oct 05, 2008
SOURCE: Not Able to Record/Playback
can't record on the my Olympus VN-1000
+ I press rec button and it just shows rec in display (no recording time is shown ONLY rec)
+ there is no play back  or stop function
+ i can only stop  rec by removing batteries (stop or play will stop rec only ONCE - but there is no  useful function - such as play or stop or rec.)
+ I tried all trouble shooting tips in manual  with no effect
+  i cleaned the spring contacts inside battery compartment that interface with the  batteries
+ it was barely used - and has not been used for a 1 year ( no batteries were inside it )     it was inside a drawer
THANK YOU
Posted on Nov 23, 2008
  • 919 Answers
SOURCE: drivers for Olympus VN-4100PC Digital Voice Recorder.
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Posted on Mar 23, 2009
SOURCE: Unable to record
I was using my voice Digital Recorder VN-6200PC. I was recording a my lesson when the screen shows formatting, I immediately took out the battery as not to lose any data, because I was taping and it began to format and I lose the data I was recording. So this time I remove the battery. However when I put back the battery it began to say imput blocked. Please help?
Posted on Oct 05, 2010
My olympus vn-8100 flashed system error and stopped working
Ok, try this, works for me:
- Remove the batteries- Insert its again- Connect the recorder via usb to pc- Copy one by one each archive you need to recover, after copy delete them from the recorder- Copy SYSTEM, RECORDER AND MANUALS FOLDER to pc- Format from the pc the recorder (i use a mac - disk utility) yes it is, ERASE!- Copy again the folders: SYSTEM-RECORDER-MANUALS- Unplug the recorder, remove the batteries, insert again- Turn on the recorder, it will display a different error, format the recoder, it will restore and reset the systems files.- It works for me!-
Jan 10, 2012 | Olympus VN8100PC Voice Recorder
I can't turn my olympus digital voice recorder WS-450S on, even with a new battery, i hadn't used it in a while, so i was shocked that it didn't work. It only turns on if i plug it in to the computer, but...
I've got this same problem :( Turns on when I plug it in to the USB, stays on when I disconnect it but if I turn it off I can't turn it back on again. It is showing a "battery low" warning and I tried to charge it via the USB last night, but it seems to stop charging after a while and despite being left for a good time last night, this morning it is the same and I've had another battery low warning.
I've just found the full pdf manual online, and have found (on page 80) a reference to it not always behaving stably when connected via a USB hub. I'm going to try to charge it via a direct port and see if that fixes it.
Oct 17, 2010 | Olympus WS-100 Digital Voice Recorder
Unable to record
Jul 18, 2010 | Olympus VN6200 Digital Voice Recorder
Will not turn on
Make sure that the device is not in the Hold position. This might be why it keeps shutting itself off. Hold is basically like the on/off button.
Jan 07, 2009 | Olympus VN-960 Digital Voice Recorder
Won't turn on
It seems to be working now....I am keeping my fingers crossed. Being that my technology skills leave something to be desired, I fixed it the old fashioned way. Took the batteries out, blew hard into the battery space, put the battery back in and said a little prayer. It turned right on....
Jan 04, 2009 | Olympus WS-110 Digital Voice Recorder
Power and file problem
make sure the battery is inserted correctly...else you will need olympus repair
Aug 09, 2008 | Olympus WS-100 Digital Voice Recorder
Olympus DM-20 Voice Recorder not turning on
Check the batteries contact especially at the battery cover. It may happened rusty if you leave the battery for a long time when the recorder not in use.
May 20, 2008 | Olympus DM-20 Digital Voice Recorder
Olympus VN-240 is dead
clean out the battery compartment with alcohol
or else repair
Sep 01, 2007 | Olympus VN-240 Digital Voice Recorder
Televison & Video Logo
Top Olympus Televison & Video Experts
ray gallant
Bill Boyd
Are you an Olympus Televison and Video Expert? Answer questions, earn points and help others
