Pixelization usually around six in the evening. Picture okay most of the rest of the time. Midco cable connection. All cables have been replaced trying to solve the problem.
SOURCE: Monitor keeps blank even the power lLED is on green
I suspect the problem is with the monitor itself. I have had the same problem. I reported it to Dell and they sent me a new monitor within a few days the problem resurfaced again on the new monitor. They have since sent me a new monitor and the problem has disappeared. The Dell customer service people sounded rather cagy to me when I suggested that this was a problem endemic to this model. The replacement monitor that I have had a sticker on the box that read "refurbished". This is a rather new model of monitor to already be into selling "refurbished" models. If you are still under warranty I suggest you call them. And even if you aren't, call them anyway. I sense that they know about this problem.
Posted on Nov 07, 2006
  • 77 Answers
SOURCE: blue snowy pixel areas on my plasma
some of these panels were mis-calibrated from the factory after not aging long enough. Let the TV run for atleast 2 hours and adjust the Vs and Vscan voltages. When it is blue in the left I have found generally the Vs is about 10 volts too high.
Posted on Jun 25, 2007
  • 4402 Answers
Convergence amp ic bad
Or send to
Posted on Feb 12, 2008
  • 124 Answers
SOURCE: Sharp Aquos LC-65D64U Picture Quality
You need to change your TV's settings and enhancements. Directly from the store and out of the box, the settings are adjusted for easiest sell in the store. That means that:
Your contrast is cranked to 100. Move this down to 50 to 60.
Your brightness may also be cranked up high. Lower it to a level nearer the middle range but not so dark as to lose detail in the shadows.
Your TV is set on "Dynamic" or "Vivid" mode. Pick "natural" or "normal" or standard.
Your sharpness is at least on, if not cranked up. Turn sharpness down or off, and the same with "Edge Enhancement" and "VSM", all to off.
Lastly, I bet you upgraded size and you are now sitting too close to the TV. Roughly, if you are sitting closer than 130 inches (about 11 foot) you might do some rearranging or save some money and get a smaller TV.
Posted on Apr 08, 2008
  • 1554 Answers
remote from cable box has a zoom , press #
Posted on Apr 26, 2008
The tv is connected to foxtel box when the tv is on the tv picture freezes and is pixeled. Do I need to purchase a scat cable with the six leads red-yellow and white plus green red and blue or can you...
It will be best for you to buy such a cable. Now it is digital processing problem that occurs. By connecting this type of connection will reolve your problem. Ok.
May 20, 2011 | Televison & Video
No picture and when vga plugged into computer the screen keep blanking out
VGA is a high capacity video cable requirng for computers to have an enormous pixel density to capture to display beyond to another set devices. Usually with VGA cables, each devices computers, televsions, DVRs have to be high defination devices. Recent innovatons are all enabled to functions with VGA, only requires ascertaining the methods of connections. For example, VGA cables performs with capacities that disallows for the TV or computer to be connected to several devices that also request amount of extensvievss in pixel definitions.
Feb 14, 2011 | QPS Q-see QC444 Video Surveillance System...
I just bought a Samsung 40" LCD 1080p 120Hz HDTV. I don't know too much about HDTV's, but I'm having really bad problems getting my Xbox 360 to look even remotely good on the tv. I have it set up through...
1. Check what resolution your xbox is sending to your tv. It should be set to 720p 1080i or 1080p in the video setting on the xbox
2. Make sure you are not also connecting to xbox with the composite video cable(yellow, red ,white). Should just be the hdmi running to the tv
Sep 07, 2010 | Televison & Video
Pixellation on most channels
The pixellation on cable channels usually indicating poor/weak cable signal. You may want to have the cable signal strength check out by the cable company, check your cable connection at the entrance of the house to make sure they are clean and tight, try connect and disconnecting them. You are not the cable company cable box are you? My had to be replaced twice by Comcast, they were running very hot.
Jul 04, 2010 | LG 42LC2D 42 in. LCD HDTV
My hp pavilion tx1000 laptop display got off( not displaying any thing
Two possibilities, your backlight is loose and needs checking or even replacement, or the cable connecting your screen is loose or mulfunctional. The first case if the most likely and common case. Considering how narrowly your screen connects with the rest of the computer and how on many occassions people 'just looove' to swing that screen around, it comes as no surprise that after a while it would start acting up. If you're into dismantling and reassembling computers, well, try and access the cables connecting your scree, check them and make sure they are okay, next, check your backlight and all its connections just to make sure everything is seated okay [all the above will require that you open a few things here and there] Good luck
Jul 11, 2009 | HP Pavilion TX1000Z Notebook PC
Pixelated lcd tv picture
usually this issue is caused by a week signal issue, those tv's need a stronger signal than an analog tv, i would call the cable company, have them come out and hook a meter to that cable, they may sujest a house amp, usually charge 50 bucks for it
Jan 11, 2009 | Televison & Video
Mitsubishi 52 lcd 120 hz receiveing time warner digital cable via hdmi cable has fuzzy and pixelated picture even on digital and hd channels. Time warner techs are comming out this week to check it out,...
The tv is fine.We see so many problems with cable provided signal that it isn't funny.It usually stems from bad cable boxes and low signal coming into the house.
Mar 03, 2008 | Televison & Video
Picture breaking up
Picture breaking up is usually caused by signal lost, does it do it while you watch a dvd? or vcr?
i f not i would have cable company check the antenna connections.
Dec 12, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue snowy pixel areas on my plasma
Jun 16, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
