Question about Pool & Spa
Our air jet tub will turn on with the button ok but it only runs for about 30-40 seconds then shuts off any suggestions
    Top Expert:
  • Pool & Spa Master
  • 50,093 Answers
The switch that the air button works is not flicking over to stay in the on position
replace the switch at the end of the air line
Posted on May 10, 2017
  • 7 Answers
SOURCE: Only 3 of 6 jets in jacuzzi tub working
Make sure the jets themselves are fully opened. Some models you can turn individual jets on & off
Posted on Dec 12, 2008
  • 35 Answers
SOURCE: I have an american standard
Check the air vacuum switch and line as you may have a air vacuum leak. The button that controls the on and off to the jets is an air vacuum switch....It may have a slow air leak in the line or connections that is activating the on and off control
Posted on Dec 16, 2008
PartsCenter
  • 125 Answers
SOURCE: kohler whirlpool will not shut off and sounds like about to blow
Sounds as if you may need a new switch to turn the tub on/off. You can find one on our site www.uspartscenter.com
Posted on Mar 04, 2009
  • 80 Answers
SOURCE: whirlpool tub, jets come on and won't shut off. No water in tub.
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
Posted on Aug 21, 2009
  • 80 Answers
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Posted on Sep 05, 2009
Why do jets turn on, then shut off?
the motor protection device is sensing to many amps. could be a flow restriction or the pump motor bearings are going bad.
Mar 06, 2016 | Jacuzzi Home
Aqua Glass whirlpool, Indulgence collection, pump turns on and works briefly, then jets stop.
First of all, what you have is a WOW pump that has an E-switch for a control.
There is a knob on the top lip of your tub that you turn a 1/4 turn to turn this pump on/off.
There is a small circuit board inside the box on top of the motor. This is likely the source of your problem.
Here is your biggest problem. That little circuit board is not made anymore. We have the e-switch but you will be better off changing out the pump (which you have to do anyway) with a new WOW pump with an air switch and change the switch on the top lip of the tub to an air button which will turn the pump on/off.
Rod
US Parts Center
Apr 13, 2014 | Whirlpool Safety Bath Walk In Bathtub -...
Aquaglass whirlpool tub
if timer and power ok, jets may be clogged. try running for 10-15 minutes after tub filled. It may unclog.
Oct 06, 2013 | Home
Maax tub
Some air jet bubbler blowers are designed to run for 5 to 10 minutes after you drain the tub to push all of the water out of the air channels. It should shut off on its own once it senses all of the water has been blown out. If it continues to run much longer than that, then contact the mfg for a service call. You have a warranty if it is a recent purchase that should cover it. Hope this helps!
Sep 10, 2017 | Home
My jacuzzi bath tub will not shut off.I have reset the breaker, blown out the plastic line and air is coming out the other end but still wil not shut off. We have only used this tub 2 or three times. Any...
It sounds like your pump in turning on/off with an air button on the top of the tub.
The pump not turning off could be either a bad air button, not sending enough air through the tub to operate the air switch in the motor or it could be a back air switch in the motor where the air hose attaches to it.
Take a large straw and blow into the air switch and see if you can operate the air switch on/off.
If it will turn on/off then you know you have a bad air button on the tub however, if you cannot get it to turn the pump on/off then you know you have a bad air switch in the motor.
Rod
US Parts Center
888-521-6183
Feb 26, 2013 | Home
RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,: My jacuzzi tub jets run for ONLY about 5 minutes b...
you have a bad motor - when a motor overheats there is a sensor inside the motor that will shut if down so as to not damage the windings and such. once your tub has cooled down for 10 mins or so it will turn back on. the fact that you can push the button multiple times just means that you are turning the air switch on the back of the motor on/off until you get to the point where the motor has cooled down and will turn back on. if you do not push the air button after the tub shuts down and you finish your bath then when the pump cools down it will come back on because the air switch in the motor is latching i.e. it is either on or off. Since you left it in the on position the motor will come back on once the motor has cooled down.
May 17, 2010 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Whirlpool tub, jets come on and won't shut off. No water in tub.
Jun 13, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
I have an american standard air tub and cannot get the air jets to shut off.  They turn off, but come back on automatically a short time later.  How do I shut the power off?
Dec 16, 2008 | American Standard 2748.328 Town Square 5'...
"high pump" (jets) shutoff
look at circit board see if it s burnt replace
Sep 30, 2008 | Waterway 1 Hp 115 Volt 2 Speed Side...
Pool & Spa Logo
47 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
