Question about Whirlpool Microwave Ovens
Whirlpool microwave light flickers when door is opened
techman
  • 3130 Answers
SOURCE: Stuck Microwave door
The button assembly or the arm thats attached to the push button is broken. With the unit unplugged. Carfully take off the screws from the sides and around the back of the unit around the outside of the cover. Now once apart, DO NOT TOUCH any electrical parts. Look at the mechanism and see if you can see why the buttons not activating an arm to trigger the door latch. If you think you see why, Go to http://www.repairclinic.com and enter your model #.. Answer the questions and then a bunch of parts will come up. If they dont then get the tele # from there and call them. Depending on how old the oven is, you may want to consider a newer oven??. Good luck
Posted on Jul 30, 2006
MicrowaveSvc
  • 9085 Answers
In most cases this is due to a broken door opening lever or loose or broken door latch / hook parts. They can only be accessed and examined if the cover is removed from the microwave. In many over the range models, you can access the door parts by removing the control panel assembly. Sometimes you may be able to get it open by pushing up gently on the bottom of the door while pushing the button, in case you need to empty it.
Posted on Nov 02, 2006
MicrowaveSvc
  • 9085 Answers
SOURCE: Whirlpool Microwave GT4175SPS0 - door
This model appears to be a counter top model (if not, please reply back, since procedure differs).
You will first need to unplug the unit and remove the outer cover.
Then you'll be able to see inside where the door open button presses on the release lever, which lifts up the hook-like projections (latches) on the door so that the door will open.
Usually the part that breaks is the release lever.
You can find helpful exploded views for similar models (such as the GT4185) here, but your best bet is to call the number at that site.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 26, 2008
keithd2704
  • 56 Answers
SOURCE: The light is not on in the microwave when I open the door
Depending on the model, you might NOT be able to replace the bulb yourself.
With many microwave appliances the bulbs are located in a secure area away from the cooking area of the machine. If you look inside the oven, you should see an area that looks like a grill of sorts. This is most likely where the bulb is located and might not be readily accessible for you to replace unlike a conventional oven light bulb is.
Verify first where the bulb is located. If it is located in an enclosed area of the oven, you might need to call for onsite service from Whirlpool to replace the bulb. Most likely this is the case. And you should ask yourself:
1- Is the unit in warranty still?
2- If YES, then call Whirlpool Service to have it worked on
3- If NO, then ask yourself, how much do I really need a light, because to have someone come out and service the unit will cost about $100+ USD to get it working again.
I know this is not what you wanted to read as a solution, but it might be the only thing to do. There is no listed part number for a replacement bulb therefore, it is a service installable part only.
Hope this helps you out.
Cheers,
Keith
Posted on Jan 02, 2009
SOURCE: Whirlpool Gold Accubake system microwave indicates
I just had the same problem with my microwave. First DISCONNECT THE POWER. Remove the front top grill (screws are on top of microwave). Unscrew the one screw at the top of the control panel and lift it out of the way. You will see three micro switches to the left of the pannel. I bent the metal frame they were mounted to by hand to move them back into place. The microwave oven works great now. If this does not help, then I would consider replacing the top limit switch.
Posted on Sep 05, 2010
Flickers off and on
Looks like a bad door switch or door switch mount.
See my help file on door switches here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
May 12, 2013 | Microwave Ovens
Oven display flickering and when I open door the light flickers and makes a sound
I'm guessing your model number is JVM1850- or JVM1860-series microwave.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee. Details are here.
Jan 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Flickering
Magnetron is bad/shorted. Not economical to repair. Replace microwave.
Sep 14, 2017 | Whirlpool MT2110SJQ 1100 Watts Microwave...
Microwave not working
HI, this is a faulty control panel. replace asap if possible.
May 29, 2009 | Whirlpool Microwave Ovens
Door latch and Screen
This is because of the broken latch. There are switches inside the oven that are operated by the door latches to make sure you're not trying to use the oven with the door open. With the new door, your oven should be back to normal.
Feb 06, 2009 | Whirlpool Microwave Ovens
Power setting, whirlpool microwave
My Whirlpool MD 377 is not headting. The light inside is blinking when open the door.
Oct 10, 2008 | Microwave Ovens
My Microwave flickers and buzzes
This problem normaly happens when the door is not closed properly for a long time and flashing and buzzing starts to give user a indication for same. Allthough it is not risky as microwave oven has safty door switches wich does not allow oven to operate while door is open. Take care and close the door properly before you leave kitchen..
Aug 02, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
Microwave Ovens Logo
705 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
