Question about John Deere Garden
To remove blades on john deere LA 150, is it clock wise or counter clock wise?TIA. Bob
  • John Deere Master
  • 7,515 Answers
Repair your vehicle right away. Just click on the link I attach.
John Deere La150 Service Repair Workshop Manual
Posted on May 15, 2017
Were are grease point for la 120 john deere riding mower located
wheels and spindles you may have greaseable blade towers
Jul 03, 2016 | John Deere Garden
Where can I get a wiring diagram for a LA 150 John Deere mower?
type your question into google and click images
just type wiring diagram for.............
if no joy try wiring schematics for,,,,,,,,
May 10, 2016 | John Deere Garden
23hr. kohler starter shaft runs clock wise. should run counter clockwise
Check the battery connections. Engine will not run backwards.
Most of the components are electrical and will operate on reverse voltage. The battery charger off of the fly wheel would not like the battery to be reversed.
Mower always have a negitive ground. Only older John Deere tractors have a positive ground.
Hope this helps?
Apr 14, 2016 | Garden
WON'T THROW GRASS
Is the belt put on right. If not the blades might turn backwards. Check and see if the blades are turning clock wise. They should be.
Aug 27, 2014 | John Deere Garden
I am burning up deck belts on a 2 year old John Deere LA 105 mower
make sure the pulleys are free the check the arbor brakes
Apr 03, 2012 | John Deere Garden
Needing to change the 12 inch blade on a Dewalt chop saw. How do I remove theblade guard and remove the bolt out of the saw. Is the bolt clock wise or counter clock wise
I don't believe you have to take the guard off,just roll it back out of the way so you can get a wrench on the nut. The rotation is clockwise to take it off.
Aug 30, 2011 | Garden
Can not remove the old blade
1. Unplug the saw.
2. Locate the blade lock button used to lock the motor shaft when changing a blade. For your saw, this button is usually located on the left side of the blade guard somewhere around the motor housing.
3. Push the button while rotating the blade until the button engages and the blade will no longer turn.
4. Use the wrench that came with the saw (or another wrench) to loosen and remove the blade bolt. For your saw the bolt should have standard right hand threads which means you loosen the bolt by turning it counter clock-wise.
5. Remove the old blade and replace it with a new blade of the same mounting type. Some blades have a round through hole and some blades have a diamond through hole.
6. Re-install the blade bolt and tighten clock-wise while holding the blade lock button down.
Oct 03, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Cant get blades off
Clockwise, but you need a good impact, or you'll have to give the wrench a good whack (which isn't a good idea). It's best to lock the blade down so it can't come around and cut you. Also, it's a very good idea to remove the spark plug wire.
Best regards, --W/D--
Aug 12, 2009 | Mtd Products Yard Machines 158CC Tiller
Installing custom handgrips on victory 8-ball
Cut the grips with a box knife ir razor blade. Twist counter clockwisw and pull while twisting. Put the new grips on with a counter clockwise twist but rub egg white on the bars and inside the new grips. The egg serves as a lubricant when wet and as a glue when dry.
Please rate this solution. Thanks!
Mar 26, 2009 | 2008 Victory Vegas 8-Ball
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
