Question about Microwave Ovens
I have a frigidare gallery microwave Fgmv175qfa, that has an internal fan that won't stop running and the interior light is on. Tried to unplug for a while, but it comes right back on.
  • Microwave Ovens Master
  • 9,098 Answers
May 24, 2017 - It may be a shorting relay on the the control board, or a problem with one of the door switches or its mount.
I regularly repair these microwave controllers and details are here.
I would need the FCC ID number off the model tag to look up the schematic.
It's best to follow up with me directly.
(FixYa does not notify us directly when follow-ups are posted, so we have to log in to the site to see them.)
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Posted on May 25, 2017
red-pt
SOURCE: Over the range microwave
I have the R-1460 in the same series with the identical symptoms. After reading MicrowaveSvc's solution I started taking apart to view the door switches and found the upper door switch to be the problem, but not a switch failure a support failure. A small bottom plastic support post that holds the switch in place was broken (probably from repeated use/abuse) allowing the switch to move when the door hooks were engaged, thus not actuating the button switch. Since the problem was mechanical rather than an electrical bad switch, I made a small support arm for the switch from an old plastic mechanical pencil and glued it in place to hold the switch in its correct position. Problem solved, microwave works! Thanks to MicrowaveSvc's description of door switches.
Posted on May 26, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: keypad on microwave wont work
This may have already been dealt with, but others can benefit from an accurate, thoughtful reply to this problem.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
SOURCE: Fans continues to run.
door switches or control circuit, may be loose contact or open check all wiring and circuit...
Posted on Dec 18, 2007
SOURCE: microwave wont come on at all.
replace the fuse. You have to remove the top grill and then you will find it above the display
Posted on Dec 29, 2007
localwonder
  • 6784 Answers
SOURCE: microwave buttons not responding - microwave running constantly with door shut
OK, you will need to replace the magnetron and the touch pad as well. this will fix this issue.
Posted on May 29, 2009
Frigidaire gallery microwave light stays on and internal fan stays on
Good Afternoon Friend, thank you for your post!
I see that the internal light and fan continues to run on your Electrolux microwave with the door close. This sounds like the issue is related to a faulty door switch. I am fairly confident that an authorized service agent will be able to restore your microwave to its normal operating condition. You can often locate a qualified service technician on the manufacturer website. Hope this helps! - Z
May 20, 2014 | Microwave Ovens
Model 85610 shut off and won't turn back on
  • Magnetron failure
  • Door interlock failure
  • Control board failure
  • Internal fuse failure
Jul 22, 2017 | Kenmore Microwave Ovens
Fan runs when door is closed and no time set.
Some GE units were starting on their own. I would definitely unplug this oven and call GE to make sure yours wasn't one of the ones being re-called.
Feb 14, 2013 | GE Advantium 120 Convection/Microwave Oven
2006 Frigidare Gallery Series 7G61704301 dosn t work
Did you have a power surge? Try unplugging the unit for 10 min and plug back in to reboot the curcuit board. If letters and numbers are being displayed it usually means the board is confused or fried.....
May 06, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Frigidare FMV156DCG Overheated?
I have the same problem....I think its the door switch because if you lift up on the door handle while you've got the timer counting down, it should start the microwave hum....
Apr 26, 2009 | Electrolux Microwave Ovens
GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Nov 15, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
161 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
