Question about Troy Garden
I have a Troy Built Super Bronco CRT tiller that would not start so I took the carberator off and cleaned it with no problems. But when It started and I moved the throttle it would die .
4 Suggested Answers
SOURCE: BELT PLACMENT ON TROY BUILT TILLER MODEL
I am assuming your belt broke and you cannot find the replacement.
I had to go to an old timer that owns his independent business and he was able to find a much better belt than the one that came on the tiller. The Belt # is 1916657 and it is 25.5 inches long and 1/2 inches wide. It also has a kevelar core that will stand up to the constant gearing up and down.
Lowes was NO HELP AT ALL!!!!
Hope this at leasst get;s you in the right direction
Posted on Apr 25, 2009
jyackle5
  • 8197 Answers
SOURCE: I NEED A DIAGRAM OF A BRIGGS AND STRATTON TROY
Go to link below for a parts break down for your tiller. Starts on page 23
http://dl.owneriq.net/c/c23c1d7c-74ff-4347-b31e-a0ee0462b35e.pdf
Posted on Apr 17, 2010
  • 11 Answers
SOURCE: How to adjust carburator on a Troy-Built super bronco tiller
Find the adjustment screws on the front of the carburetor. Then Start the engine and let it warm to normal operating.
Adjust both screws equally and find the right mixture.Bring both screws up slowly and listen until the engine purrs smoothly. Any raggedness or rattling is a sign of too lean a mixture. Keep turning until you find the sweet spot.
Posted on Sep 21, 2015
What is the spark plug gap for the engine of a troy bilt super bronco crt tiller
go to troy blit and input model number, this will tell you what you need to know
Jan 22, 2015 | Troy-Bilt Super Bronco 16-inch 208cc...
Why does my troy bilt super bronco will not roll unless it is running
-You have to shift to Neutral before it can roll free.
Good luck
Mai
Aug 29, 2014 | Troy-Bilt Super Bronco 16-Inch 208cc...
Compression check engine
should be 80 and above but should start at 60, but have low power, you may need valve, ring work
Nov 23, 2013 | Troy bilt Super Bronco Tiller 208cc
Not getting gas to my 6.0 bronco tiller
Did you leave gas in it all winter with out stableizer in it Well you need to clean out your hole carberator or do you have a fuel shut off on this
Mar 21, 2011 | Troy bilt Super Bronco Tiller 208cc
Tiller will not keep running
Have you tried squirting gas into carburetor to see if it will keep running? If that keeps it running as long as you are squirting gas in it, your carb need to be cleaned out/repaired.
May 26, 2009 | Troy-Bilt Garden
Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
May 20, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
BELT PLACMENT ON TROY BUILT TILLER MODEL 21A-643B711 SUPER BRONCO CRT
Apr 17, 2009 | Troy-Bilt Garden
I just purchased a troy bilt bronco crt tiller. Put oil and gasoline in. Pulled the cord. It started. Ran maybe 15 or 20 seconds and stopped. When I tried to start it again, the cord would not...
remove the spark plug.  And pull the cord again.  if the carb float is stuck down or you overfilled the oil you could be hydro-locking the engine.  Check.
Mar 29, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Garden Logo
29 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
