Item stuck in washer - Washing Machines
  • 153 Answers
Get physical assistance and read menual and dont put too much clothes in it.
Posted on Jul 25, 2009
  • techno girl Jul 25, 2009
    get physical assistance and read menual and dont put too much clothes in it.
Drum is stuck
hi have u lost any small items i have done a few washers were socks get throungh gap in drum at front when they role up between inner and outer drum they will lock it up
Feb 14, 2014 | IPSO Parts IPSO 223/00102/40 Washer...
Clothing stuck in washer machine
Is it stuck in the center agitator or the out tub?
Jul 04, 2008 | Washing Machines
My crosley washer keeps popping my breaker
This is a vertical modular washer.
If you have items stuck between tubs or something in the pump that could possibly be the problem. The washer is fairly new to the market . Use the service manual I provided to diagnose the problem and report back to me would you? It could be helpful to a bunch of folk.
Oct 26, 2011 | Crosley CAWC529JQ Top Load Washer
Error code f-51
The F51 code indicates that the control is not detecting proper motor rotation in the washer. This can be caused by overloading the washer, a fill problem or even a toy or item that is stuck underneath the washer that is preventing the motor from spinning properly. With the washer empty, see if the spin basket rotates freely. If you detect resistance, then you check between the basket and tub for an item that is stuck in this area.
Feb 05, 2011 | Maytag Bravos MTW6600T Top Load Washer
Machine is stuck on fast spin.
First Start your machine with a low spin and slowly slowly increase the speed until it becomes fast I hope it helped : )
Aug 25, 2010 | GE WBSR3140DW Top Load Washer
Whirpool cabrio won't spin cycle
I just paid $85.00 for a tech to come out and pull some socks out that got stuck between washer drum and outside plastic drum. It took 10 mins. top.
It seems when you pull clothes out of washer small items slip between inner and outer drums. BAD DESIGN.
Jul 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer wont drain
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
May 02, 2009 | Frigidaire FEX831CS Top Load Stacked...
Barrel will not spin, sounds like motor is running.
check the p-trap for stuck loose items---change,rocks,etc.. I had the same problem and the technician said the placement of the p-trap causes lots of loose items to get stuck, which causes the washer not to go thru its cycles & won't spin.
Apr 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Small items stuck under the agitator
it should have a cap on top with a bolt underneath it that you can take loose.the top of the agitattor should pop off
Nov 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer will not spin
is the door lock lit make sure the door is closed all the way make sure the dispenser door is closed all the way their is a magnetic switch in it that will not let the washer spin if its not closed it also will not spin a small load try adding a couple of items let me know if this does it or not
Jan 11, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
