Question about Pool Pump Pool & Spa
Information on bearings replacement intelliflo 4 160 pool pump motor
Is it possible to replace the bearings on the pool pump motor intelliflo 4 160
    Top Expert:
  • Pool Pump Master
  • 6,889 Answers
Less hassle replace whole pump if bearings are overheating its ruining seals next motor will go bad armature
Posted on Nov 23, 2017
  • 9,845 Answers
If you have the necessary bearing pullers and the replacement bearings and the shop press, then go for it. Otherwise, a new motor is the best bet.
Posted on May 10, 2017
Pentair Intelliflo vs. Need bearing replacement for front and back bearings
Pentair WhisperFlo Pool Pump Motor Bearings Replaced ...
? 2:03
www.youtube.com/watch?v=qYRNMCh_7kM
Jul 10, 2012 - Uploaded by Pump Repair Supply
More Help & Information: https://pumprepairsupply.com Watch as Joseph shows you how quite your Pentair
Sep 27, 2015 | Pool & Spa
Bearings for electric motor
replacing bearings can be tricky, but if you are willing to try most of these motors use 6203 2rs c3 bearings all for the back bearing, the front could be 3 different sizes. after removing them bring the rotor to your local pool pump motor repair shop, and have them remove and replace. about $20.
Jul 15, 2015 | Hayward 2HP Pool Pump Motor A O Smith...
Pump high whisperflo 177476
bad bearings replace motor or pump
Jun 23, 2013 | Pentair Intelliflo Pump 4x160
Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -leaks from housing
Which part of the housing?
The back against the motor or against the strainer basket housing?
Parts break down for the Pentair IntelliFlo VS-3050 here.
If leak is on the back of the housing - shaft seal. Or if the leak is on the front the replace O-Rings #10 or #23 in diagram.
Sep 13, 2012 | Pentair IntelliFlo VS-3050 & VS+SVRS...
My pump has water squirting out the sides, can you tell me what to do? It also shuts off after a short time.
sounds like it needs a volute gasket, you can remove the six bolts that hold the wet end to the seal plate and replace the gasket. It's the same color (almost) as the pump body. The shutting off part can be a number of things. It can be a flow issue, possibly caused by the leak. Intelliflo pumps are tricky, if replacing the gasket does not help the shutting down problem, you may have to call a tech. There are many variables that could cause that.
Apr 03, 2010 | Pentair IntelliFlo High Performance Pool...
Pool & Spa Logo
49 people viewed this question
Top Pool Pump Pool & Spa Experts
Lawrence Oravetz
john h
Steve Buck
Level 1 Expert
Are you a Pool Pump Pool and Spa Expert? Answer questions, earn points and help others
