Sounds like it wants to such up water, but doesn't.
My Neptune washer doesn't empty all of the water. Is it suppose to hold water?
The Maytag Neptune front load has a liquid counter weight that makes it sound as though it is not empty. This is a normal sound, they all sound like that, even mine.
Jan 26, 2013 | Maytag Neptune Washing Machines
Ford explorer 99 door sound doesn't stop even though all doors are closed. what can I do for this annoying sound?
sounds as if your weatherstrips are leaking try spraying water from a hose around the door jams, then look around inside the car door (open) for evidence of water getting past the weatherstrips, where you find water in the car- that's where the air is getting in
Sep 07, 2012 | 1999 Ford Explorer
Maytag Neptune TL washer doesn't stop adding water
it sounds like your drain hose is to low it needs to be 3 feet high if its to low this will cause the water to syphon out and keep refilling
Nov 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
This fountain is located at my church, the problem: The water dispenses, then it doesn't. Wait a while and it dispences again, then it doesn't. It did not do this before now it does...
sounds like there is a build up of minerals in the water line that is coiled around the cooler unplug from wall take off cover and run fine wire through copper tubing
Aug 02, 2011 | Elkay EZS8-L Single-Level Wall Mount Water...
We have a kenmore humidifier on the furance model # 48945. it doesn't stop running so our water bill is twice what it should be. I've tried to find a manuel on line so i can figure out how to...
Noodles, it sounds like the float valve inside the water reservoir is stuck in the down position. Turn the water line ON/OFF valve to the humidifier OFF. Open the top of the reservoir and you will see the float valve. Gently, lift it up, to see if it will remain at the top of the water level, which left in the reservoir. It it doesn't, then the float needs to be replaced. In the mean time, leave the water line ON/OFF Valve OFF.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 07, 2011 | Kenmore Humidifiers
My knemoor dishwasher doesn't seem to be getting water. When I dump water in to the machine it runs but otherwise it seems to be water starved??help!
It sounds like the pump, the function of which is to pump water into the machine. Since it works when you add water manually, it doesn;t sound like a switch or anything.
A pump is easy to replace. It's usually attached with just a few screws/bolts and the hoses.
Feb 14, 2011 | Kenmore Dishwashers
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
Location of the thermostat and water pump
Doesn,t sound like your thermostat or waterpump. Sounds more like your headgasket has gone.
May 20, 2009 | 1992 Toyota Camry V6
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
