Question about Microwave Ovens
How do i change the power level - Microwave Ovens
How do I change the power level?
Usually, power level is selectable using the keypad.
Jan 03, 2016 | Samsung 1.8 Cu. Ft. Over-the-Range...
How do I set the power at 50%?
After first setting the cook time---then hit the power level button and hit the number 5 (for 50%) and then start. Power level can also be changed while running by hitting power level button and selecting 1 through 10. For example level 3 is 30% for defrosting.
Mar 20, 2015 | GE Profile Spacemaker XL 1800 36"...
Hamilton beach microwave change power level hp-p100n30al-s3 how do I do that? I pushed the power level button and only beeps does nothing to it
Hit power level button then number 1 through 10. Most have 10 power levels. 1 is extremely low. 3 is usually defrost, 5 would be half power and so on.
Feb 27, 2015 | Hamilton Beach Microwave Ovens
Unable to adjust power level, the power level button on the control panel does not respond.
Try pressing and adjusting the power level before setting the cook time, or maybe before pressing start. Worked on my Panasonic
Dec 12, 2013 | Microwave Ovens
How do you change the power level?
On most brands, you enter the cook time, then press the "Power Level" key, followed by the using a single digit key for the desired power percentage, then hitting "Start".
EXAMPLE: Too cook for one minute at 30% power:
Time Cook > 1 > 0 > 0 > Power Level > 3 > Start
A possible alternative key combination may be:
Time Cook > 1 > 0 > 0 > Power Level > Power Level >Power Level > Start
Here is a guide to power levels:
May 21, 2013 | Rival Microwave Ovens
How do change the power level?
My GE Microwave Oven won't let me change the Power Level. It is on 10 and takes forever to warm up food. It is supposed to default to Hi but doesn't. I followed the directions for changing the...
There is a solid state switching device called a triac "electronic voltage controller" that has malfunctioned, it controls the power level settings when making power selection, It will need to be replaced to correct the problem. This repair should be done by a qualified technician because dangerous high voltages are present.
Jun 07, 2011 | Microwave Ovens
How can I change the power level on my GE Spacemaker microwave? When Power Level button pressed, I keep getting the message: "Power level may not be changed at this time".
You can download your owner's manual here.
May 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven
maybe it is running. you can not change power while the unit is running. you can only set the power level while programming the heating schedule.
Feb 18, 2008 | Microwave Ovens
Changing the power level
I had the same problem. All you need to do is put in your cook time first, then adjust the power level. So time cook, whatever # of minutes, power level, then # power level. Hope this helps.
Nov 29, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
