Question about Garden
Can you help me get a ground drive belt schmatic for a S1642
3 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: I need a digram of replaceing a drive belt on
You can download the owners mqnuqal here:
http://dl.owneriq.net/2/2141e15a-36a6-9594-0166-6f10fba50f44.pdf
It has full instructions as well as diagrams
Posted on Sep 23, 2009
jpmaly
  • 6 Answers
SOURCE: install drive belt for scotts s1642 rider lawn mower
check size of belt make sure its correct make sure routing is correct andput belt on tension pully last you may have to pull on it to get it around it
Posted on Aug 30, 2012
What size belt does my lawnmower take its a Craftsman lt2000 model# 917.275762
How would someone know that,
unless they had the same product ?
You have no owners manual or service
manual?
All you have to do, is remove the old belt,
& read the numbers on it
You can stop by any small equipment shop & give
them the old belt or the make & model numbers & they
will look up the new belt
Oct 03, 2014 | Garden
Install drive belt for scotts s1642 rider lawn mower
Aug 30, 2012 | Garden
I have a 2000 mustang. headlights and high beams do not work. the running lights (parking lights) work. replaced the switch and fuse and still do not work
Do you have a volt ohm meter check if you are getting voltage to the head lights if you are check the ground if you do not have power to the light sockets you sould get a schmatic for your cars electrical system to start tracing your wireing . Hope this helps
Aug 19, 2010 | 2000 Ford Mustang
I need to see a belt routing diagram for a Scotts Mower
This is for a Scotts 1642. Picture yourself sitting on the mower looking down at the deck. Starting at the tractor pulley, the belt runs from the right side of this pulley to the left side of the tension arm pulley, around this pulley to the left side of the right hand side mower blade pulley, around this pulley, across the deck to the smaller left hand side idler pulley, then up to the left hand side mower blade pulley, around this pulley to the second (larger) idler pulley, around this pulley and back to the left side of the tractor pulley. If you make a small sketch of the deck pulley arrangement it will be easier. Keep in mind some of the pulleys are for the "V" side of the belt and some (The tension arm pulley & larger idler pulley) are for the flat side of the belt. Be sure the belt is not twisted and lays in a continuous circle with the "V" side of the belt on the inside before you start.
from http://www.ssbtractor.com/wwwboard/view_all.cgi?bd=lawn&msg=135
Please vote !!
May 12, 2010 | Garden
Where do I get a schmatic wiring diagram for
Try Cbtricks.com .hope this helps you
Feb 28, 2010 | Radio Communications
I need a digram of replaceing a drive belt on s1642 scott lawn tractor.
Sep 23, 2009 | Garden
LTX 1000 CRAFTSMAN /42 IN. DECK BELT LODGED ABOVE PULLEY AND STOPPED MOWER AND BROKE BELT. IS THE BELT SIZE 96 OR 97 INCH? THE BELT HAS DONE IT TWICE/STCK BETWEEN THE PULLEY AND THE THING ABOVE IT.
Without the model number, I couldn't tell you what belt goes on the ground drive. That 174883 is a 5/8 x 97" and is your deck drive belt. Your ground drive belt may just need replacing. They will wear thin and loosen up between the pulleys and cause the problems you're having. The old belt may still have the numbers on it.
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Does scott mower #S1642 have a magnito? if so how do I access it?
no there is no magnito. what is the problem you are having, i can help you.
Jun 25, 2009 | Garden
Product instructions
You can change the belts from the bottom, remove the brush roll, then you can reach thru slot to change the pump belt, then the cogged belt. Wasn't sure which darwing you wanted, if it is electrical, let me know.
Dec 27, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
